Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 30th December 2012, 02:58 AM   #231
Truetone is offline Truetone  Australia
Outputs to GND measured with Fluke DMM
DVCC 3.7V (not lit up)
VDD 1.2V
VDD_XO 3.3V
thanks
Old 30th December 2012, 03:44 AM   #232
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by manudrz View Post
I've tested one of my blue led, it lights up with two aaa batteries, and I measured 2.7V, I think I'll try these leds on the lock/mute
Might work fine, but might be a bit dim with the stock resistors.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 30th December 2012, 03:45 AM   #233
Russ White's Avatar
VDD 1.2V
VDD_XO 3.3V
thanks
DVCC should be 3.3V - it must be damaged.
Audio
Old 30th December 2012, 04:05 AM   #234
Can I order a replacement? I will order the Placid at same time. Is it safe to use like this or should I wait?
thanks
Old 30th December 2012, 04:14 AM   #235
Russ White's Avatar
Yes, we offer replacements. 3.7V is above the rated voltage. Probably best to wait.
Audio
Old 30th December 2012, 04:43 AM   #236
No need - just found a dry solder joint on the centre GND leg - now 3.3V and all lit up like Gotham City :-) yay!
Old 1st January 2013, 06:45 PM   #237
Russ White's Avatar
Originally Posted by RollE2k View Post
Still wondering when the OTTO 4:1 will be avalible?
Please see this thread, and weigh in.
4:1 or 4:2 mux....
Audio
Old 8th January 2013, 08:24 AM   #238
datazone is offline datazone  United States
Default Buffalo-IIIse DAC - supply list
Hello Russ n Brian -
I'm a bit new to the diy DAC world, I work in the music industry- record production - mixing mastering etc. We work mostly with 24bit 96k files for now, currently are audio stage is as follows - (protools) Digital Audio Interface (digi002 rack) direct out via S/PDIF (RCA) to a Roland M1000 digital mixer DAC- to Powered monitors. It sounds good, but after hearing what so many have said about the ESS Sabre32, I'm now interested in building a custom DAC to replace the Roland...
So my question is this.
What do I need to purchase from you to get started?
Audio Requirements:
1 S/PDIF (RCA) input
2 XLR outputs
maybe a headphone jack.
Thank you for your time in advance.
Old 8th January 2013, 04:58 PM   #239
LeonvB is offline LeonvB  Netherlands
Audio Requirements:
2 XLR outputs
Everything is documented in the integration guide: http://www.twistedpearaudio.com/docs...ide_V2.0.0.pdf
Well everything but the kitchen sink, but rest assured: you don't need one for this build
Old 8th January 2013, 05:06 PM   #240
Hello Leon,
I'll take a look at the pdf.. Do you know which Crystek Clock is being used
CCHD-950 or CCHD-957?
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
