Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 29th December 2012, 01:52 PM   #221
Russ White's Avatar
Send a message via Yahoo to Russ White
For safety, your chassis should be connected to mains earth. Nothing else need be.
Less pulp more juice Twisted Pear Audio.
Old 29th December 2012, 02:01 PM   #222
BrianDonegan's Avatar
If you do decide to connect the DAC/PSU/Signal grounds to the chassis ground, do so in only one place (star ground). Multiple ground paths will result in ground loops and noise.
If you are using TPA components and wiring correctly, the DAC's ground will be connected to the PSU's ground and the output stage's ground already, so only one connection to the chassis would be needed.
Twisted Pear Audio
Old 29th December 2012, 03:27 PM   #223
Thanks guys, Everything worked perfectly from switch on. I have the ps in a separate box (earthed) and just ran 2 wires to the dac. The transformer secondaries are 0v referenced at the power amp only.
May I say huge thanks for the great sound - really enjoying it on usb - not just flac files etc sound good, but listening to U-tube jazz lessons is a whole new experience.
At present using a 317 reg ps - planning to upgrade to Placid. Any comments on difference to expect?
best wishes, martin
Old 29th December 2012, 04:27 PM   #224
manudrz is offline manudrz  France
Instead of the green leds mounted on the PCB, can I put two blue leds (mute/lock) on the front of my box ?
Blue leds are 2 mm - 3V - 30mA max
Also, to get a little off buffalo-topic, when I'm sure placids work properly, can I remove the green LEDs? I'm afraid it could illuminate through my air holes :/
Old 29th December 2012, 06:02 PM   #225
Russ White's Avatar
Blue LEDs have a bit too much forward voltage.
No you cannot remove the LEDs from Placid - they are an integral part of the circuit.
Old 29th December 2012, 06:03 PM   #226
Russ White's Avatar
best wishes, martin
Glad to hear it!
The difference is subtle, but things will definitely be a bit better.
Old 29th December 2012, 06:46 PM   #227
Ok, I let the green ones in place...
Old 29th December 2012, 07:42 PM   #228
I noticed the green LEDs on the DVCC Trident don't light up (they are all lit on the VDD and VDD_XO) Is this normal? I have confirmed the ps voltage at the input is correct (5.25v)
thanks,
Old 29th December 2012, 11:48 PM   #229
Russ White's Avatar
thanks,
No. It is not normal. What is it's voltage output?
Old 30th December 2012, 12:58 AM   #230
I've tested one of my blue led, it lights up with two aaa batteries, and I measured 2.7V, I think I'll try these leds on the lock/mute
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1270 16th May 2013 07:23 PM
Buffalo III Build Thread dheming Twisted Pear 8 7th May 2012 01:13 PM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
Copyright ©1999-2013 diyAudio
