#161 |
Placid HD setup is identical to the positive side of the Placid HD-BP.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 27th November 2012 at 12:05 AM. |
#162 |
I just started assembling boards for my Buffalo-IIISE and have a couple of questions related to the IVY-III board whose manual hasn't been updated recently.
#163 | |
My mistake about SW1. Not dip-switches but a relay to mute the single-ended output until to voltages are established.
#164 |
Can anyone comment on whether a chassis for the Buffalo-IIISE with IVY-III and power supplies needs vent slots or holes for heat removal?
#165 |
It's a good idea. Since the Trident regulators are shunts, they generate heat by their nature. If you are using shunt pre-regulators, such as Placids, you will get a lot of heat from them as well.
Twisted Pear Audio |
#166 | ||
#167 |
is it possible to buy the Buffalo IIIse DAC just as a kit, to save some cents? Many thanks, tom |
#168 |
No, only as a assembled module. It would be too much work/support to offer it as a kit.
#169 |
Finished my buff3se and very happy with it, very high quality kit and sound.
I noticed the led's on XDD-XO Trident board aren't lighting up. Reg is working ok ,input 5.25V , output 3.4V. Is this normal? |
#170 |
No, its not normal.
| Thread Tools | Search this Thread |
| Buffalo III - flexibility without compromise. | Russ White | Twisted Pear | 1270 | 16th May 2013 07:23 PM |
| Buffalo III Build Thread | dheming | Twisted Pear | 8 | 7th May 2012 01:13 PM |
| Buffalo III and Integer / HOG | jtwrace | Twisted Pear | 5 | 19th January 2012 05:41 PM |
| WTB: Buffalo II/III DAC | merlin2069er | Swap Meet | 1 | 10th January 2012 05:50 PM |
