Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th November 2012, 07:38 PM   #121
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - SE
What size spacers are needed for mounting the various modules to one another? I cannot find any info about the spacing between the boards when stacked.
All mounting hardware is included in the kits, including stacking spacers (when appropriate).
FWIW: I supply .5" F-F spacers and screws for all modules. When stacking is an option, I also supply .625" M-F spacers.
Old 12th November 2012, 07:39 PM   #122
Buffalo III - SE
Originally Posted by nvduybom View Post
For complete the buffalo dac IIISE with 2 s/pdif input . I will need the following modules ?:
-Buffalo-IIISE 2-Channel DAC $379 USD
-Legato v3.1 Kit for Buffalo-II $115.00 USD
-Placid HD Power Supply Kit $60.00 USD
-Placid HD Bipolar Power Supply Kit $90.00 USD
-15V+15V (30VA) Power Transformer $25.00 USD
-9V+9V (15VA) Power Transformer $23.00 USD
The S/PDIF transceiver module is required for buffalo III SE?.
that looks about tight. You do not need the S/PDIF transceiver module for the Buffalo. It accepts S/PDIF directly.
Old 12th November 2012, 07:41 PM   #123
Buffalo III - SE
Originally Posted by dahlberg View Post
Hello.
It just ordered two of these for use in a 4-way dsp filter (spdif-out ).
If I'm using the digital volumecontrol can I still use just one pot
(in parallel) or is there need for a second one for some reason ?
You can wire the output of the volume pot to each of the DACs and control then both at the same time, as long as both board share a digital ground.
Old 12th November 2012, 10:24 PM   #124
RollE2k is offline RollE2k  Sweden
Brian: But how do you do with the BIII-SE if you want say one I2S/DSD input, and three SPDIF? You have to buy the old MUX?
Old 12th November 2012, 10:53 PM   #125
Buffalo III - SE
We will be releasing a digital switch, like the OTTO, but 4:1 instead of 2:1. We will (hopefully) be ordering boards this week.
Old 13th November 2012, 01:34 AM   #126
lhquam is offline lhquam  United States
What connector/cabling is recommended from the S/PDIF UFL connector to the back panel BNC, RCA or XLR input connector? For short interconnect distances is there any reason to use balanced XLR for the S/PDIF or AES/UBU input vs. BNC or RCA?
Old 15th November 2012, 03:15 AM   #127
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
These cable connect is included in kit ?.
Old 15th November 2012, 08:02 AM   #128
Truetone is offline Truetone  Australia
Sorry if this should be obvious, but pls can you confirm if the input accepts I2S and DSD data streams. Presumably it detects DSD and processes accordingly. This is how I understand the input spec, but could be wrong.
An external switch (Otto) is only for if you want to connect 2 x devices. DSD and I2S from the same device will be processed OK.
Thanks,
Old 15th November 2012, 11:38 AM   #129
Buffalo III - SE
I use regular wire if the distance is short (twisted if you can).
If you are using AES/EBU, you should use an XLR for the balanced signal.
Old 15th November 2012, 11:39 AM   #130
Buffalo III - SE
No.
Buffalo III - SEHide this!Advertise here!
Buffalo III - flexibility without compromise. Russ White Twisted Pear 1373 17th January 2018 10:39 AM
Buffalo III Build Thread dheming Twisted Pear 11 26th February 2014 02:30 AM
Buffalo III and Integer / HOG jtwrace Twisted Pear 5 19th January 2012 05:41 PM
WTB: Buffalo II/III DAC merlin2069er Swap Meet 1 10th January 2012 05:50 PM
