#91 |
I guess I do not understand the implications of BrianDonegan's statement:
"You do not need the Metronome with the Buffalo, unless you are using an older source with less than 64fs PCM (such as the CD-Pro transport). How is the SqueezeBox-3 S/PDIF output characterized? |
#92 |
I examined the S/PDIF output from my SqueezeBox-3 Classis with an oscilloscope. With idle output I see "mostly" a square wave with an approximately 700ns period with means a frequency of 1.428 MHz. That is approximately 32 times the 44.1kHz sample rate output from the SqueezeBox. When I play music, I see transitions at twice that frequency, ie. 350ns between negative pulse transitions. Does that mean the output is 64fs and does not require using the Metronome?
#93 |
You do not need the metronome with the Buffalo-III, in fact, using it would be redundant, and would likely result in worse performance. The Buffalo-III includes its own (better) masterclock and upsampler, and it upsamples to a much higher rate than the metronome is capable of.
There will be no problem running the SPDIF output of your Squeezbox directly into the Buffalo-IIISE, in fact, this approach will result in the best perfromance possible from an SPDIF source. |
#94 | |
Thank you, that is (part of) the answer I was looking for. I have been trying to understand the 64fs part of the response fromBrianDonegan: "You do not need the Metronome with the Buffalo, unless you are using an older source with less than 64fs PCM (such as the CD-Pro transport)."
#95 |
Was talking about I2S, not SPDIF. The Buffalo-IIISE is ready to go for any SPDIF source. In fact, it is easier to use than the Opus because the Buffalo-IIISE automatically switches its filters and upsampling to suit any incoming sample rate from 44.1 to 384.
So, you do not need a metronome, and for best performance, just run a single SPDIF input directly to the board. If you want to add USB, this will be easy to do as well when TPA releases their (long awaited) asynchronous USB receiver-to accommodate a single SPDIF and the USB receiver (which will output I2S to the Buffalo) you do not need any additional input board, you just need the I/V stage and power supplies to suit... |
#96 | |
There are some gaps in the BIIISE configuration, like how to get AES/EBU input or how to cheaply get 3-4 S/PDIF inputs (the classic Receiver/Mux is $129) but perhaps modules that offer this functionality will be introduced later on. |
#97 | |
![]() I also have a WavIO board (WaveIO | Luckit). I guess it is no problem connecting that for USB input... |
#98 | |
Yes, the WaveIO will be very easy to hook up, especially with the B-IIISE, as you can use u.fl cables for the I2S lines. |
#99 |
Well, I was planning a set up with an Ivy en two Placids. I know it 's difficult to discribe the differences, personally I hope the step up is as big as the financial differences between the Opus and Buffalo
#100 |
Hi
I use an IDE drive (pc) as a source for my cd, which I added a 75ohm transformer sc947-02 to convert the TTL-out to "real" SPDIF-out. If I understand correctly, the SPDIF-in is converted by the Buffalo so I think removing my sc947-02 and connect directly the drive and the dac in TTL level, is it okay? My drive is a asus E818A4 with a dedicated psu |
| Thread Tools | Search this Thread |
| Buffalo III - flexibility without compromise. | Russ White | Twisted Pear | 1278 | 1st June 2013 02:12 AM |
| Buffalo III Build Thread | dheming | Twisted Pear | 8 | 7th May 2012 01:13 PM |
| Buffalo III and Integer / HOG | jtwrace | Twisted Pear | 5 | 19th January 2012 05:41 PM |
| WTB: Buffalo II/III DAC | merlin2069er | Swap Meet | 1 | 10th January 2012 05:50 PM |
