Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 21st March 2015, 01:39 PM   #61
Russ White is offline Russ White  United States
Russ White's Avatar
It precisely what it is designed to do. So yes - of course it is up to the task.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 22nd March 2015, 12:57 AM   #62
Mull3t is offline Mull3t  United States
So then the ball is back in the S03's court. It sounds as if the OTTO is agnostic to whatever is thrown at it. I'll most likely give it a go then.
Old 28th July 2017, 05:33 AM   #63
wcwc is offline wcwc  United States
Can the switch be used to switch analog outputs?
I would like to switch the outputs from a DAC and an analog source to use the same amplifier. So I need to go from 2 to 1.
Introducing OTTO2Hide this!Advertise here!
Introducing... seventenths Music 2 26th April 2008 03:21 PM
Introducing myself... despotic931 Introductions 3 13th February 2008 03:09 AM
Introducing Myself - Greetings! brucedog Introductions 3 30th October 2007 03:59 AM
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
