Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 26th October 2012, 06:00 PM   #41
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing OTTO2
Originally Posted by orpheus View Post
Any issues with chaining OTTO's? I have a USB to i2s converter, the MUX, and the DSD output from my SACD player via Teleporter to input to my Buffalo II. I thought I could use one OTTO to switch between the MUX and the SACD and output to another OTTO to switch between OTTO #1 and the USB to i2s converter. Would this cause any problems?
Stated more simply, three i2s sources(1, 2, 3), two OTTOS(A, B).
1 & 2 switched with OTTO A.
3 and OTTO A switched with OTTO B connected to the Buffalo II.
I could keep all the wires very short, stacking the OTTOS.
Thank you for your time and help.
-Aaron.
That should work fine.
Old 26th October 2012, 06:17 PM   #42
Russ White is offline Russ White  United States
Russ White's Avatar
Yes you can absolutely do that.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 22nd February 2013, 01:06 PM   #43
Zebb is offline Zebb  United Kingdom
All of Otto-II's inputs and outputs seem to have pull-down resistors (or are they pull-up). Why is that? Are they really needed?
Old 22nd February 2013, 01:27 PM   #44
Russ White's Avatar
Because it is good engineering practice. It keeps drains and sources referenced to GND even if they are left open.
It is a mux/demux so what is an input or an output is totally up to you.
Of course you can omit them. But I wouldn't. They do no harm.
Audio
Old 14th March 2013, 09:54 PM   #45
DQ828 is offline DQ828  Australia
DQ828's Avatar
So what resistor banks should I buy for switching between SPDIF inputs?
Old 16th March 2013, 05:12 AM   #46
DQ828's Avatar
Ok, don't panic, I found them, didn't see them hiding amongst the terminal blocks that I hadn't opened.
Old 15th August 2013, 09:13 AM   #47
albertob is offline albertob  Spain
Default Led in otto2
Hello, I'm using a otto2 to switch between i2s and spdif using a switch. Operating properly. I would like to place an LED to indicate signal which is in use, how I can do it with otto2?. Thank you!
SF Cremona clone DIY speakers
Old 15th August 2013, 10:39 AM   #48
DQ828's Avatar
You could use a 3 Pole Double Terminal switch, (3PDT)
Old 16th August 2013, 01:29 PM   #49
Introducing OTTO2
-Aaron.
That should be fine. It will come down to keeping the wiring neat.
Old 2nd January 2014, 11:42 AM   #50
RollE2k is offline RollE2k  Sweden
i forgot to ask - if using external MCK from say two i2s sources - does this "switch" really work problem free with up to 100MHz?
Introducing OTTO2Hide this!Advertise here!
Introducing... seventenths Music 2 26th April 2008 03:21 PM
Introducing myself... despotic931 Introductions 3 13th February 2008 03:09 AM
Introducing Myself - Greetings! brucedog Introductions 3 30th October 2007 03:59 AM
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
