Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 29th September 2012, 12:08 PM   #31
Russ White is offline Russ White  United States
Russ White's Avatar
"S" stands for switch.
It takes LVTTL input. It does not matter where it comes from. That is your choice.
I would have answered sooner, but I did not got a post notification for some reason...
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 29th September 2012, 12:51 PM   #32
orangeart is offline orangeart  United Kingdom
Thanks Russ, that's great, as mentioned earlier, I have a 'spare' way on my 4:1 mux. I was intending on routing this vdd from the mux via the switch to the 's' pad. Would it need to go via a resistor? Presumably I don't need to tie the gdn from the mux over to the otto as well?
I like the way this forum sends you a notification when someone answers. PFM uses the same software but I don't get notifications from there
Thanks for helping out.
Stefan
Old 30th September 2012, 12:46 AM   #33
Russ White's Avatar
You always need to make sure two circuits that share logic are at the same ground potential. The means connecting GND. Unless you use some sort of isolation.
I would keep the S input at 3.3V max.
Audio
Old 30th September 2012, 12:46 AM   #34
Russ White's Avatar
Audio
Old 30th September 2012, 08:11 AM   #35
Great, i think these two circuits will share a transformer, so gdn will be connected. What is the current draw of the switch so that i can calculate the value of pull down resistor? I presume the switch vdd from the mux has the same voltage as the psu feeding it?
Thanks Russ, good work.
Stefan
Old 30th September 2012, 12:34 PM   #36
Russ White's Avatar
It is a logic input, high impedance. You would need a voltage divider or level shifter if your starting voltage is > 3v3V. Say 5V.
Audio
Old 16th October 2012, 07:11 AM   #37
bobkojek is offline bobkojek  Indonesia
does OTTO will switch with no problem when both of source have different audio format output? (source A format 16 bit/44.1kHz while B format 24 bit/96kHz)
And will that kind of config will make problem when to be used with Metronome?
thanks
Nicko
Old 17th October 2012, 10:56 PM   #38
Russ White's Avatar
It does easily pass two different input signals.
The second part of your question is less straightforward. It will depend on unknown parameters.
Audio
Old 18th October 2012, 03:09 AM   #39
Thanks for the answer, from what i experienced when used that config with Metronome before Opus made problem for source with 44.1 kHz format, the sound sometimes not came through or the sound skip a lot.
But when direct from OTTO to Opus the sound came out normally.
thanks
Nicko
Old 26th October 2012, 05:47 PM   #40
orpheus is offline orpheus  United States
Any issues with chaining OTTO's? I have a USB to i2s converter, the MUX, and the DSD output from my SACD player via Teleporter to input to my Buffalo II. I thought I could use one OTTO to switch between the MUX and the SACD and output to another OTTO to switch between OTTO #1 and the USB to i2s converter. Would this cause any problems?
Stated more simply, three i2s sources(1, 2, 3), two OTTOS(A, B).
1 & 2 switched with OTTO A.
3 and OTTO A switched with OTTO B connected to the Buffalo II.
I could keep all the wires very short, stacking the OTTOS.
Thank you for your time and help.
-Aaron.
Introducing OTTO2Hide this!Advertise here!
Introducing... seventenths Music 2 26th April 2008 03:21 PM
Introducing myself... despotic931 Introductions 3 13th February 2008 03:09 AM
Introducing Myself - Greetings! brucedog Introductions 3 30th October 2007 03:59 AM
introducing... lecky Introductions 3 2nd May 2006 09:51 PM
Just introducing myself. 3beanlimit Introductions 0 5th August 2001 04:23 AM
