Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 3rd November 2013, 06:18 PM   #61
4est is offline 4est  United States
Default Trident failures
I have just had my second 1.2v Vdd Trident failure. The first time I was mucking about occasionally, and thought it could have been something I did. This time it happened out of the blue after the DAC had been running for months without change. I have my Placid set at 5.05v, but have noticed that the new recommended input voltage is 5.25v. Could this be it, or is it a design flaw possibly? I took this as a hint that it was past time I upgraded to version 3, but still I would like to know if I should be doing something differently.
TIA!
Old 4th November 2013, 12:30 PM   #62
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Trident Evolves - Version 3
TIA!
What is the failure mode, and how are the Tridents mounted?
Old 4th November 2013, 01:13 PM   #63
barrows is offline barrows
Default No Worries...
4est. If you replace with the newer version you will have no more failures. I experienced a couple of trnasistor failures on the old Trident 1.2 V version as well. It is a heat issue due to the voltage drop this reg has to deal with. When I repaired mine I actually made two tiny heat sinks out of some copper sheet, and glued them to the transistors, everything ran smooth then for a long time.
But the new Tridents have beefier transistors and exhibit no such problems. Upgrade the AVCC as well, you will not be sorry.
Old 4th November 2013, 02:11 PM   #64
Honestly I have not attempted to repair the Tridents as I had a replacement on hand last time, and want the new version this time.
Old 4th November 2013, 02:14 PM   #65
Thank you Barrows, that was what I was looking to know! They were mounted vertically ala the original BII style.
I replaced the AVCC straight away when they came out and loved the change- better PRaT, more organic.
Old 2nd May 2014, 09:20 PM   #66
drone is offline drone  Germany
Default Trident 1,2 V Q1/Q2 replacement?
one of my 1.1 version of 1.2 V trident stopped working. So I would like to replace the transistors Q1/Q2. I have some bc860C type. would this be ok?
thx
branko
Old 3rd May 2014, 03:07 AM   #67
thx
branko
Yes.
Old 5th October 2016, 10:20 PM   #68
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
I have a spare unused V3 Trident configured for 1.2V, which I can make use of if I can reconfigure it for 3.3V. I've done some research and believe I can do that by setting R3 = 100K and R8 = 1K47
Will be grateful if this could be confirmed.
Many thanks
Old 5th October 2016, 10:43 PM   #69
Many thanks
Correct.
Old 6th October 2016, 05:10 AM   #70
nautibuoy's Avatar
Thanks again Brian
Trident Evolves - Version 3Hide this!Advertise here!
Trident preorders yammy1688 Twisted Pear 6 30th October 2015 03:12 PM
V3 trident coolhead Twisted Pear 7 14th March 2012 02:18 PM
Trident - Three-leg Shunt Regulator IngemarR Twisted Pear 34 4th May 2011 11:33 PM
trident series 65 schematics iz Parts 6 30th September 2010 03:12 PM
