Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th April 2012, 10:48 PM   #21
barrows is offline barrows
Default well
Originally Posted by sureshm View Post
Any tips on how to easily remove the old tridents? Thanks
Be careful! I cut the standoffs first, to get the regs out of the way. Then wick away as much solder as possible. Then one can remove the remaining posts one at a time-heating the post will also release it from the plastic (as the plastic softens), or one can gently pry the plastic up from the board, and cut the stand offs, and then remove one at a time. The plastic spacer will move on the posts with the application of a little heat.
Just do not use too much force, which could damage to board, work slowly and patiently.
Old 14th April 2012, 10:55 PM   #22
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by Russ White View Post
If you have access to hot air rework station it is pretty easy to remove the tridents.
If I had, I wouldn't make the proposal. And I don't think the average DIY'er has.
Old 14th April 2012, 10:59 PM   #23
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
I understand, I am just saying that is the easiest and safest way to do it.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th April 2012, 11:06 PM   #24
avr300's Avatar
I know. It just a matter of a few mils, then the wick would be so much efficient.
Just trying to suggest the "next-to-safest" to be event more safe. It's painstaking to see your via pulled out with the component leg.
Old 15th April 2012, 03:31 AM   #25
Jeffrey Davison is offline Jeffrey Davison  United States
this worked a treat:
RadioShack® 45-Watt Desoldering Iron - RadioShack.com
JD
Old 15th April 2012, 08:00 PM   #26
AndriyOL is offline AndriyOL  Ukraine
There is more simple solution. When you solder to dac board pin headers just solder to tridents female headers as well.
If for pristine and pure adoration - it's diyAudio dedication!
Old 15th April 2012, 11:58 PM   #27
Russ White's Avatar
I was just going to say that.
If you fancy changing things up - headers are always the best choice.
Audio
Old 23rd April 2012, 09:29 AM   #28
sinski is offline sinski
I installed the new Tridents two weeks ago on my BII and there is improvement in all areas. Most noticable is more analogue, less digital warm sound and stronger more precise DEEP bass, more details from background, better 3d stereo imaging, and, and and ...
TP rulez
Old 25th April 2012, 01:48 AM   #29
F1 FAN is offline F1 FAN  Canada
Any time line when they will be available again?
Old 25th April 2012, 02:13 PM   #30
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Right now
Trident Evolves - Version 3Hide this!Advertise here!
Trident preorders yammy1688 Twisted Pear 6 30th October 2015 04:12 PM
V3 trident coolhead Twisted Pear 7 14th March 2012 03:18 PM
Trident - Three-leg Shunt Regulator IngemarR Twisted Pear 34 5th May 2011 12:33 AM
trident series 65 schematics iz Parts 6 30th September 2010 04:12 PM
Copyright ©1999-2017 diyAudio
