Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 13th March 2012, 03:03 PM   #1
coolhead is offline coolhead  Malaysia
Default V3 trident
I know that TP already selling it in their web site. I have older version of trident, may I know what has change and can the older version do the upgrade?
Thanks.
Old 13th March 2012, 05:52 PM   #2
atoluma is offline atoluma  France
May have you read "Trident III" but it is "Trident for Buffalo III"...
Old 13th March 2012, 06:26 PM   #3
Look at this tread R4 resistors on Trident Regulators - Trident Regulators - Twisted Pear Audio Support
Both Russ and Brian mention trident V3 and compare it with V1.1 which is the old type.
Old 13th March 2012, 07:12 PM   #4
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
V3 trident
The change in Trident was primarily to enable it to run at higher voltages (for future Opus VA duties, etc). We replaced the opamp with a higher voltage unit, and changed the shunt transistors to SOT-223 form factor. We also added an SMD spot for R4 so I could pre-mount the current setting resistor, mainly to save the time required to get them ready (labeling resistors is a time consuming task).
Old 14th March 2012, 01:01 AM   #5
Brian,
Can the upgrade (op-amp and shunt transistor) be applied to older trident v1.1? Any benefit doing it for Bii?
Thanks for the information.
-coolhead
Old 14th March 2012, 01:08 PM   #6
Russ White is offline Russ White  United States
Russ White's Avatar
I will start a new topic so I can introduce it properly.
The Trident 3 update would be worthwhile for any app. It is a better circuit and natural evolution and I am very pleased with the feedback from users and testers that made that evolution possible.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th March 2012, 02:52 PM   #7
Thanks Russ, will be looking forward for that.
Old 14th March 2012, 03:18 PM   #8
Russ White's Avatar
Here you go!
Trident Evolves - Version 3
Audio
V3 tridentHide this!Advertise here!
Trident preorders yammy1688 Twisted Pear 6 30th October 2015 04:12 PM
FS BII 80 MHz+ Combo Trident 3 regs. merlin el mago Swap Meet 5 18th October 2011 05:42 PM
Trident - Three-leg Shunt Regulator IngemarR Twisted Pear 34 5th May 2011 12:33 AM
trident series 65 schematics iz Parts 6 30th September 2010 04:12 PM
