| Twisted Pear Superior quality electronic kits |
Could I send lpcm to the buffalo 3 with a box like this?
I am ubnsure how rto fix the inverted lfe and center though. I do not have the spdif board just wondering if it would work just tapping the output like is done here on the sil9135. Cypress CLUX-11SA |
#2 |
That should work fine, but you can only use one SPDIF input at a time on the Buffalo. You could try extracting eight channels of I2S instead.
EDIT: I am pretty sure the audio will be downsampled however.
Twisted Pear Audio Last edited by BrianDonegan; 28th February 2012 at 11:57 AM. |
#3 |
That is sort of what I am asking.
In the picture shown in the photo with the wires RP36 and RP33 are they the correct wires for the I2S? Here is more info on the board S/PDIF General Installation (I do not have the switchbox board I just was going to use it to wire the I2S from the hdmi to the buffalo) It is not downsampled I have tested with 192 24bit lpcm and it passes fine over the hdmi and also the spdif output but that is only 2 channel. Would the bit transporter work for this?? |
#4 |
I don't see any reason why it wouldn't work just fine. You would need two Teleporters to transmit all four I2S data streams, plus LRCK and BCK.
Twisted Pear Audio |
| HDMI and digital out | ackcheng | Digital Source | 18 | 12th November 2011 05:26 PM |
| HDMI on/off switch? | theAnonymous1 | Everything Else | 6 | 19th December 2010 05:26 PM |
| Laptop HDMI Output and DAC HDMI I2S Input. Can I get this going? | mikone | Digital Source | 1 | 7th September 2010 11:36 PM |
| Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 06:47 AM |
| HDMI question | zimjj | Multi-Way | 1 | 16th November 2008 06:29 AM |
