Introducing the bit "Teleporter" - Page 9 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 22nd January 2012, 11:55 AM   #81
BrianDonegan's Avatar
Originally Posted by dr_faulkner View Post
Another use for the Teleporter will be to connect to a digital crossover or equaliser.
I use a couple of DEQX units connected to the XONAR card configured as quadrophonic and then feed their digital output into Buffalo DACs that, in turn, feed each individual speaker driver (the DEQX allows discrete calibration of each individual driver as well as being a crossover and room eq).
Tapping into the I2S made an astounding difference. The Buffalo DAC in concert with the digital processing capabilities of the DEQX is simply astounding. Unfortunately, running I2S any real distance is extremely problematic - particularly at higher bitrates. Hopefully, the Teleporter is the answer to my prayers :-)
Sounds like it's just what the doctor ordered...
Old 29th January 2012, 08:06 PM   #82
Any news about the disponibility? Thx
Old 30th January 2012, 08:56 AM   #83
acidbrain's Avatar
What would be the maximum I2S cable length you can use between Metronome and B2/3 ?
Old 30th January 2012, 01:42 PM   #84
merlin el mago's Avatar
Originally Posted by Russ White View Post
Absolutely. This is make it practical to use PCM(I2S or otherwise) and DSD from separate components.
I have successfully tested up to 100ft.
Old 30th January 2012, 01:53 PM   #85
acidbrain's Avatar
What would be the maximum I2S cable length you can use between Metronome and B2/3,
Without using the teleporter?
Old 30th January 2012, 04:18 PM   #86
neb001 is offline neb001  United States
In the Buffalo integration guide it states:
 Keep I2S cables as short as possible, for high resolution sound one should keep them at least below
4 (10cm) and of equal length.
Old 30th January 2012, 04:40 PM   #87
There are no absolutes. It depends heavily on the environment (EMI, RFI, wiring, proximity to power lines, etc). Shorter is better. They can longer until they stop working or become polluted with noise.
Old 30th January 2012, 04:41 PM   #88
NicMac is offline NicMac  Italy
NicMac's Avatar
The Teleporter uses differential transmission and I seem to remember that Russ said that it worked nicely with a 30m spool of cable
Old 30th January 2012, 04:47 PM   #89
acidbrain's Avatar
Thanks everyone for your answer, look's like I'll be needing 4 of those" Scotty beam me up" devices.
Old 30th January 2012, 05:03 PM   #90
Welcome to the club
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
Copyright 1999-2017 diyAudio
