Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th January 2012, 09:06 PM   #61
karvid is offline karvid  Sweden
karvid's Avatar
Originally Posted by BrianDonegan View Post
Test rig is done, and I have started building them. I should be able to get a few for sale in the next couple days.
Any idea of the price yet?
Old 12th January 2012, 09:31 PM   #62
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the bit "Teleporter"
Price is not final, but it's looking like $40 each.
Old 12th January 2012, 10:20 PM   #63
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
Would it be possible to get a panel mounting diagram, as well? The two holes and the square hole dimensions should suffice.
Old 12th January 2012, 10:44 PM   #64
Cutout dimensions are 16.51 ± .25mm (.650 ± .010 in) across, and 13.95 ± 0.25mm (.535 ± .010in) vertically.
PDF for ethernet jack attached.
I will get a DXF file of the mounting pattern posted soon.
Old 14th January 2012, 10:12 AM   #65
dsdjoy is offline dsdjoy  Germany
Is it possible to use just one module to achieve galvanic isolation for I2S ?
I2S input => teleporter => I2S output => Buffalo III DAC
Old 14th January 2012, 11:58 AM   #66
Russ White is offline Russ White  United States
Russ White's Avatar
No.
You would need TTL I2S input => teleporter(transmitter) => DIFFERENTIAL I2S => teleporter(receiver) => TTL I2S output => Buffalo III DAC
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th January 2012, 12:39 PM   #67
There would be no ground reference at the Buffalo end to use just one half of the differential signal. You could supply that from the source, but then, well, no isolation.
Old 14th January 2012, 01:11 PM   #68
Russ White's Avatar
That and the LVDS signal level would be far too small.
Audio
Old 14th January 2012, 09:10 PM   #69
Sorry, I do not quite understand all the technical details. For dummies:
If I just want to have galvanic isolation, I'd use IL715 chips as described here:
Which Digital Isolators for I2S? …or NOT H i F i D U I N O
If I want to have galvanic isolation plus the benefit of transmiitting the signal over longer wires, I'd use two of your Teleporter modules.
Question:
To have also galvanic isolation with two of your modules, would I need to cut/break the shielding (gnd) of the ethernet cable between the transmitting and receiving module ?
Old 14th January 2012, 09:14 PM   #70
There is no ground in the ethernet connection, just four differential pairs.
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
