Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 25th November 2011, 02:47 PM   #21
Originally Posted by Skip Pack View Post
...The next question would be: Would connecting the TPA USB in
a separate box via a short USB cable to the computer and long
cables between Teleporters in the TPA USB box and the DAC
box be a better way to go?
Thanks,
Skip
That'd be my question as well Skip. My current computer source is a fair way away from my Dual-Mono Buffalo & it would be a very neat solution.
Old 25th November 2011, 11:29 PM   #22
Russ White's Avatar
Send a message via Yahoo to Russ White
Absolutely. This is make it practical to use PCM(I2S or otherwise) and DSD from separate components.
I have successfully tested up to 100ft.
Less pulp more juice Twisted Pear Audio.
Old 26th November 2011, 11:40 AM   #23
Hi Russ, great bag of tricks here
For my good understanding, would you please, confirm or not what I behave from previous reading :
1° - Source : PCM/I2S/DSD -> Teleporter Emitter -> Cat5 -> Teleporter Receiver -> PCM/I2S/DSD : DAC
2° - USB Plug -> TP New USB Receiver -> Teleporter Emitter -> Cat5 -> Teleporter Receiver -> PCM/I2S/DSD : DAC
3° - Teleporter Modules Emitters (E) and Receivers (R) are the same, configured with DIP as E or R ?
Thanks for your enlightments
Forgive me for my bad English
Old 26th November 2011, 12:46 PM   #24
BrianDonegan's Avatar
Absolutely correct, except for the bad english part
Twisted Pear Audio
Old 26th November 2011, 12:53 PM   #25
Thanks for your kindness Brian.
Only remaining question : availability ?
I'm on the rank for Beta testing.
I've got some CDP on the bench waiting for surgery... and Opus ready for direct I2S food.
Old 26th November 2011, 01:01 PM   #26
Also, each of the 4 channels can be configured as transmitter or receiver.
I will start building them in earnest this week.
Twisted Pear Audio
Old 26th November 2011, 01:13 PM   #27
Can't wait to read your work in progress
Have fun !
Old 26th November 2011, 03:01 PM   #28
4est is offline 4est  United States
What is the intended incorporation of the Teleporter into the BIII?
Presently, you have the SPDIF-4>Sidecar>BIII. I assume that the Teleporter would connect to the Sidecar, but that would only allow one i2s source. You appear to be interested in DSD and USB, leaving me with the thought that I am missing something or am confused. Both are likely!
Old 26th November 2011, 03:37 PM   #29
merlin el mago's Avatar
Count in me for 1 emiter + 1 receiver
Old 26th November 2011, 04:07 PM   #30
Originally Posted by Russ White View Post
Very easy. Just find and wire the PCM/DSD signals and a 5-7.5 power supply. Just make sure the format is correct for the target DAC.
Cut a small square hole and drill a couple holes in the back panel and you have a modded player.
You don't even need the square hole. Neutrik Ethercon connectors encapsulate RJ-45 inside the XLR form factor, so if you have an XLR hole punch you're good to go. They're back-compatible with standard ethernet cables, of course.
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
Page generated in 0.12419 seconds (74.09% PHP - 25.91% MySQL) with 11 queries
