Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 14th August 2012, 03:17 PM   #261
merlin el mago is offline merlin el mago
merlin el mago's Avatar
For I2S I connected:
pin 28: o2 for Bit Clock
pin 40: WDCK for Word Clock
pin 45: for Data
Is Ok or have I to connect pin 39: 08?
Old 14th August 2012, 03:26 PM   #262
Russ White is offline Russ White  United States
Russ White's Avatar
Merlin, you will want to have a new thread for this topic, because it not about the Teleporter its about modding your particular source.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th August 2012, 03:29 PM   #263
Have I to post in the TP support forum or here in a new thread?
Old 14th August 2012, 03:32 PM   #264
Russ White's Avatar
Lets move this conversation only to the support thread then. In any case you would have this work to do even if you were not using teleporter but had to wire directly.
Audio
Old 14th August 2012, 03:41 PM   #265
Ok I will do thanks.
Old 9th September 2012, 08:49 PM   #266
SCompRacer is offline SCompRacer  United States
Originally Posted by rolls View Post
Hello Rich
When I have got my new mechanism for my 3910, I would like to try I2S. Because this machine is very complicated, I would like to know if you have tapped I2S at the same points (attachment).
Hopefully your Denon is working properly now.
Thank you!
André
Hello Andre. I think I answered this at another forum, but if not I'll attach a pic of where. I attached at IC311 on the audio out board.
Thanks again for pointing out that DSD swapped R and L channels on the shared circuits with I2S out. Twisted Pear came to my rescue with the OTTO II, saving me from building a multiple relay board to correct that. I simply jumpered the shared wires from B1 over to B2 out and corrected the previously reversed R and L DSD channels.
Even with the lid on the Denon 3910, I still get dropouts using the Teleporters when that recliner is operated. (Upon releasing the switch). My two channel system is on a dedicated 20 amp circuit and the chair is several feet away. I don't use the Denon much so I haven't tried anything. Currently doing a dual mono build so my attention is diverted.
Old 15th September 2012, 08:48 PM   #267
Could I use the fourth LVDS pin to send MCK between my source and B3 in Synchronous mode?
Old 16th September 2012, 11:42 AM   #268
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the bit "Teleporter"
Yes.
Old 18th September 2012, 07:36 PM   #269
Teleporters handle 3.3V, are 3.3Vpp or 1.75Vpp?
Old 18th September 2012, 07:47 PM   #270
Russ White's Avatar
It is LVTTL.
Audio
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
