#251 |
The Buffalo need a 64fs bit clock but I'm not sure how much fs have the CEC TL1X.
#252 |
I connected the gnd to pin 3 (optional master clock) for emiter and receiver gnd, is wrong I need to connect the gnd to second row in both Teleporters right?
#253 |
Grounded emiter Teleporter to gnd RCA S/PDIF to 2nd row also grounded receiver Teleporter 2nd row to gnd Sidecar, now no sound no lock.
#254 |
Yes, gnd needs to connect to the second row in both teleporters. It doesn't matter where in the second row.
#255 | ||
#256 |
Due to the fact is an issue that I want to fix I posted scope pics in the right TP support forum Teleporter - Twisted Pear Audio Support
#257 |
The "issue" really has nothing to do with the teleporter.
![]() The scope pictures show it is doing exactly what it should be.
Less pulp more juice Twisted Pear Audio. |
#258 |
Yesterday ordered the Metronome just in case CEC don't have 64fs needed for B3.
#259 |
Well even more important you need to know exactly what format it is using. It may not even be a format the metronome supports.
#260 |
How do you say "deglitcher"? I ask because I read in the ic Yamaha YM7121 datasheet:
"For 1 DAC, output uses DF00 and data latch uses WDCK output, and "deglitcher" uses DGL & DGR outputs." Also said: "DF00 is serial signal for MSB first DAC, 08 bit rate (8.4672MHz), WDCK and L/R are sync. signals." Last edited by merlin el mago; 14th August 2012 at 03:13 PM. |
| Thread Tools | Search this Thread |
| Introducing: "Thesis" | tresch | Multi-Way | 13 | 13th October 2009 10:49 PM |
| THX for introducing "PC Based" | soundcheck | PC Based | 3 | 21st August 2009 05:56 PM |
| Introducing "Mork" : part 1 | Andy G | Multi-Way | 4 | 19th August 2008 05:11 PM |
| Bit of history.."Magic Brain" record changer | redrabbit | Analogue Source | 0 | 10th February 2008 07:53 AM |
| Introducing: "Sauron" | Andy G | Multi-Way | 28 | 19th September 2007 12:14 AM |
