Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 11th August 2012, 08:32 PM   #241
Russ White is offline Russ White  United States
Russ White's Avatar
Originally Posted by merlin el mago View Post
It's enough +4,83V to power the Teleporter?
Yes.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 11th August 2012, 08:40 PM   #242
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks Russ.
Old 12th August 2012, 11:25 AM   #243
BIII locks but doesn't sound
Old 12th August 2012, 12:26 PM   #244
Corpius is offline Corpius  Netherlands
Corpius's Avatar
I had a similar problem. Teleporter --> Metronome. Lock but no sound - Teleporter - Twisted Pear Audio Support
Old 12th August 2012, 01:59 PM   #245
Wich CDpro gnd are you using RCA S/PDIF gnd?
Old 12th August 2012, 02:11 PM   #246
Are you connected CDpro gnd to Sidecar gnd throught the Teleporter?
Old 12th August 2012, 05:54 PM   #247
I connected CD S/PDIF gnd trought Teleporter & direct to Sidecar gnd, still no sound.
Old 12th August 2012, 07:34 PM   #248
Corpius's Avatar
Now I have the gnd from the I2S output connected to the teleporter gnd (second row). Bit clock, word clock and data lines to the first three positions on the first row of connectors. In the dac they are connected in the same order. Otherwise the lines would get swapped.
At first I had to use a extra gnd line from my dac to the cd-pro. There was probably a large potential difference between dac and cd-pro. I connected it to one of the many gnd points at the dac and to the gnd of the cdpro. The easiest way to connect is was by connecting the rca outer shell of the dac to the chassis of the cd-pro. This solved the unlocking problems, but when I had build DAC and all related modules into a metal chassis the problem was gone! This had solved the problem somehow. All modules in my dac are floating, so not connected to earth. My cd-pro is connected to earth.
Perhaps you can try connecting it all using a wall socket that is not connected to earth. With my setup it played wonderful using such a socket. This is how I discovered the problem. Connecting it to to a wall socket that was connected to earth I couldn't get a proper lock.
Old 12th August 2012, 08:44 PM   #249
I need a Metronome between the Teleporter & the Sidecar?
Old 12th August 2012, 08:46 PM   #250
Corpius's Avatar
If you use a cd-pro as source, yes. You need to re-clock it . Otherwise the sabre dac won`t take it.
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
