#231 | |
" I love cats....but I couldn't eat a full one. " |
#232 |
All you need is an RJ45 crimped. If cables for this kind of application are something people could use, I could certainly stock different types.
Twisted Pear Audio |
#233 |
Hhhhmmmm, I have plenty of ethernet cables laying around ( those yellow and blue ones with rj45 plugs on both ends).
I was hoping just to cut the plug off the recieving end and wire directly to the teleporter in the correct fashion.Can you do it same as in say a pre amp with balanced out puts and only take the + to use for single ended ? thanks again
#234 | |
![]() Can you show me the pinout for the teleporter rx end now that you have shown me the Lite cd21 i2s pinout I will have a crack at making up a suitable cable..or maybe it would be easier to purchase one from yourself...if you would make one up for me
#235 |
The mapping is here:
Introducing the bit "Teleporter" Code:
RJ45 Pin : LVDS Signal 1 : B0 2 : A0 3 : B2 4 : B1 5 : A1 6 : A2 7 : B3 8 : A3 Which signal you use with which position is up to you. The goal of the cable will be to get the improperly pairs wires to the proper mapping right at the source connector.
#236 | |
#237 |
Any news on the manual for the Teleporter Russ ??
#238 |
space charged
See page 29 in this manual .... http://www.twistedpearaudio.com/docs...ide_V1.2.5.pdf
#239 | |
#240 |
It's enough +4,83V to power the Teleporter?
| Thread Tools | Search this Thread |
| Introducing: "Thesis" | tresch | Multi-Way | 13 | 13th October 2009 10:49 PM |
| THX for introducing "PC Based" | soundcheck | PC Based | 3 | 21st August 2009 05:56 PM |
| Introducing "Mork" : part 1 | Andy G | Multi-Way | 4 | 19th August 2008 05:11 PM |
| Bit of history.."Magic Brain" record changer | redrabbit | Analogue Source | 0 | 10th February 2008 07:53 AM |
| Introducing: "Sauron" | Andy G | Multi-Way | 28 | 19th September 2007 12:14 AM |
