Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 21st May 2012, 03:24 PM   #221
luisbock is offline luisbock  Portugal
The problem is keeping short connections. Still hesitating between Otto or 4PDT toggle from tocos. I need to input CDpro/Metronome and USB receiver, no plans for SPDIF.
Old 27th May 2012, 11:37 PM   #222
rolls is offline rolls  Switzerland
Originally Posted by SCompRacer View Post
I had lock problems with Teleporters in my Denon 3910 to my BIII DAC. The 3910 did not have a ground lug on the IEC socket. It was like that from the factory. Installing an IEC socket with ground lug and attaching a chassis ground to it fixed my lock problem.
I have to go back in and connect my I2S grounds to the Teleporters based on Russ's post. To the ground row, not to a channel position, in the DAC and CD player.
We have a powered reclining chair in the listening room. Anytime the wife reclined the chair, I lost lock, the sound cuts out. This was after my Denon ground fix. My system is on a dedicated 20 amp isolated ground circuit, the chair is on a different circuit. Is that still DC through the mains or I need to put the covers back on the DAC and CD player?
Hello Rich
When I have got my new mechanism for my 3910, I would like to try I2S. Because this machine is very complicated, I would like to know if you have tapped I2S at the same points (attachment).
Hopefully your Denon is working properly now.
Thank you!
André
Old 3rd June 2012, 07:15 PM   #223
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Default Teleporter --> metronome, lock but no sound
I'm having some problems with my teleporter-Metronome setup. Perhaps someone here can point me into the right direction. I described the exact problem and my current setup at the TPA support forum:
Teleporter --> Metronome. Lock but no sound - Teleporter - Twisted Pear Audio Support
Old 4th June 2012, 10:29 PM   #224
Thomas Giz is offline Thomas Giz  United States
Is to only me or this occurs to everyone ? The last few posts of this thread simply disappeared.
Old 4th June 2012, 10:43 PM   #225
Russ White is offline Russ White  United States
Russ White's Avatar
I think just trying to avoid the cross posting.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 4th June 2012, 11:07 PM   #226
Does it mean you're kicking me to Twisted Pear site forum now ? :-)
Ok I go peacefully ....
Old 4th June 2012, 11:08 PM   #227
Russ White's Avatar
No nastiness intended.
Audio
Old 4th June 2012, 11:13 PM   #228
I hope because if I did not enjoy so much Teleporters I would not be so nice... ;-)
Old 8th June 2012, 04:17 AM   #229
Chilli6565 is offline Chilli6565  Australia
Hi Russ,
Hope you can give me some advice.
I have just recieved 1 teleporter and I would like to use it as a recieving I2s module in a diy tda1541 nos dac.
The transport is the Lite audio cd21 with has an I2s output via rj45 plug.
I have been told elsewhere that that lite I2S is differential as well?.
Can you tell me how to connect the teleporter inside the dac ( it will be within 3 inches of the 1541 chip)
cheers
Paul
" Digital is only ac anyway "
Old 8th June 2012, 11:07 AM   #230
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the bit "Teleporter"
Code:
 Lite CD21 I2S Specifications:
1 - GND
2 - GND
3=-LRCK
4=+LRCK
5=-SDATA
6=+SDATA
7=+SCLK
8=-SCLK
While this is differential, it does not properly utilize the twisted pairs in the cable. You will need to customize the wiring on the transport end to work correctly.
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
