Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 20th April 2012, 03:10 PM   #191
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Originally Posted by merlin el mago View Post
Dou you know how much fs bit clock has the CEC TL1?
No, but if you know which transport it uses you can probably find the datasheet.
Old 20th April 2012, 03:39 PM   #192
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Sanyo SF90
Old 20th April 2012, 04:39 PM   #193
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Introducing the bit "Teleporter"
Default unlocks
Get unlocks on the B2 when anything turns on or off. Lights, motors etc., not only that but if a light dimmer is turned only part way on the lock stays off until the dimmer is turned full on or off. I'm guessing its the teleporter because this didn't occur before. Any suggestions?
https://www.youtube.com/watch?v=VCSayVA_3Cc
Old 21st April 2012, 01:11 AM   #194
ichiban's Avatar
Default Unlocks
....taking this to the TP Support Forum.
Old 21st April 2012, 12:12 PM   #195
wktk_smile is offline wktk_smile  Japan
wktk_smile's Avatar
I had met same problem when using similar LVDS - i2s transmission scheme (It's not Teleporter, built by myself )
I assume eliminating GND connection between i2s source and DAC cause this kind of unlock
issue more frequently than simple single ended i2s (including GND) connection.
Old 21st April 2012, 01:39 PM   #196
Russ White is offline Russ White  United States
Russ White's Avatar
Yes an unlock in this case is typically not about the source at all. It is usually ground bounce or DC on the mains.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 21st April 2012, 01:45 PM   #197
Russ White's Avatar
Dimmers are notorious for creating DC on mains. DC on mains can create very large EMI spikes which is why you get the unlocks.
Audio
Old 21st April 2012, 01:54 PM   #198
Russ White's Avatar
This also could also indicate (Just guessing because I have not seen it occur) that you need to make sure your source and your DAC are close to the same ground potential. The DC potential between the two may be too high. In cases like this make sure both the source and the DAC are well earthed and the problem should be resolved.
Audio
Old 21st April 2012, 06:40 PM   #199
ichiban's Avatar
Default unlocks
Thanks for the responses. Last night I did searches for lock problems on the TP Support Forum. Only got through the first three pages.
As to the ground potential difference, probably. The dac is in the living room and pc is in the kitchen, different AC lines. Getting them well grounded
could be a problem, our home built in the 50's is two wire not the three wire system.
Didn't have the lock problems when using coax to send sp/dif. Ground on cable saved the day? But I was going into the spdif-reciever then into the dac I2S inputs.
Just tried connecting pc&teleporter ground via a long wire to the dac ps.
Before connecting wire to dac I measured .23dcv & .9acv between ground wire and dac ps ground.
It did not make a difference. Lights, refrigerator motor starts/stops still cause unlocks!
I first tried the teleporters between a Phillips CD80 and the BII to transmit I2S signals. Can't recall now, if the lock problem occurred then. Both devices were on the same AC outlet. But, between every track there was a squelch. The I2S signal was tapped at the decoder output. I tried tapping at the SAA7220/DigitalFilter outputs tp the dac, but that wouldn't fly. I seem to recall that the 7220 level shifted the output to the dac for some reason!?
Old 22nd April 2012, 01:00 AM   #200
Corpius's Avatar
That is why I forbid my girlfriend to buy lights that use a dimmer. Perhaps a good mains filter (not Y-filter) will do the trick. I use medical grade filters from Corcom. They don`t have any leaking current to the main ground and no degration in sonics at all.
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 11:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 06:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 06:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 08:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 01:14 AM
