#11 | |
Cut a small square hole and drill a couple holes in the back panel and you have a modded player.
Less pulp more juice Twisted Pear Audio. |
#12 | |
I posted some numbers here: Introducing the bit "Teleporter" Much better than any of the current TTL isolator parts do.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 24th November 2011 at 07:50 PM. |
#13 |
Russ, Brian.......
....... make hundreds so we don't have to check the TPA site ten times a day to grab a couple
#14 |
I am hand building the prototypes and the first batch. After that, I will be producing them in much larger quantities. This will be a staple kit.
Twisted Pear Audio |
#15 |
#16 |
Ok dumb question fellas.
I just want to build the Buffalo III to accept USB from my Mac mini. So I take it I need: 1) The Buffalo III + Trident, PS, etc... 2) Analog output stage of choice + PS (IVY, Legato, tube, etc...) 3) The New USB Receiver that Russ is working on and do I need this 'Teleporter' or even a 'SPDIF module' if I am only going to have ONE input and that is USB? Thanks, Anand. |
#17 |
If you are putting them all in the same box, you do not need a Teleporter.
One can still be used with the USB module's lvds output, in order to gain isolation from the computer, but it is not required.
#18 |
So I only need to take the signal & ground from RCA ouput of the CD transport connect to the new module and a 5-7.5 positive power supply & the same at the BIII?
#19 |
No, that would be S/PDIF output. This module is for PCM (I2S) and DSD. It would work with S/PDIF, but there is no real need for it.
#20 | |
| Thread Tools | Search this Thread |
| Introducing: "Thesis" | tresch | Multi-Way | 13 | 13th October 2009 10:49 PM |
| THX for introducing "PC Based" | soundcheck | PC Based | 3 | 21st August 2009 05:56 PM |
| Introducing "Mork" : part 1 | Andy G | Multi-Way | 4 | 19th August 2008 05:11 PM |
| Bit of history.."Magic Brain" record changer | redrabbit | Analogue Source | 0 | 10th February 2008 07:53 AM |
| Introducing: "Sauron" | Andy G | Multi-Way | 28 | 19th September 2007 12:14 AM |
