Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 5th April 2012, 08:26 PM   #171
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Introducing the bit "Teleporter"
Originally Posted by carlmart View Post
Some questions about the TP Teleporter transceiver:
1) Does it buffer or amplify the I2S signal in any way?
2) If it doesn't then what does it do?
3) How close does it have to be, in inches or mm, to the source I2S pins on the DAC?
Carlos
1&2: It does buffer. See the DS91M040 datasheet for more information.
3. Generally speaking, it is best to keep I2S signals as short as possible, so, the closer the better.
Old 9th April 2012, 02:19 PM   #172
suffolk tony is offline suffolk tony  United Kingdom
Pending the receipt of my Teleporter (should arrive this week) I've been trying to work out the I2S output connections on my Teralink USB - SP/DIF convertor.
The latter uses a CAT5 socket to output the I2S but I've soldered some output wires directly to its output pins for the sake of neatness.
I confess to being a bit confused with the connections, which are labelled GND (no problem), MCLK (which i guess is master clock and isn't needed), LRCK (to D1), Data (D2) and SCLK, which is ? My guess is DCK but I'd appreciate some help please.
Old 10th April 2012, 10:16 AM   #173
Anyone please?
Old 10th April 2012, 11:10 AM   #174
merlin el mago is offline merlin el mago
merlin el mago's Avatar
PCM
0 bit clock
1 word clock
2 data
3 optional master clock (typically not used)
DSD
0 bit clock
1 data left
2 data right
3 (unused for asynchronus stereo - but could possibly be master clock)
Old 10th April 2012, 12:52 PM   #175
Hi Merlin, thanks, I did read this but couldn't quite understand -
I'm connecting I2S, which is the same as DSD? It seems I need to connect up from my Teralink I2S to the Teleporter as follows :-
Teleporter
0 = SLCK (on Teralink)
1 = LRCK " "
2 = Data " "
I therefore ignore the ground connection and the MCLK connections on the Teralink? All help gratefully received!
Old 10th April 2012, 01:06 PM   #176
It doesn't matter which signal you tie to which teleporter channel, as long as you use the same arraignment on both ends. The order you list will work fine.
Old 10th April 2012, 04:54 PM   #177
bikerboy is offline bikerboy  United States
Default Teleporters
HI,
I have the teleporters up and running.
PC->Teradac Terelink module via I2s ->Teleporter->6'cat5->Teleporter->I2s input on sidecar.
Set the transmit teleporter to open/off and the receiver teleporter to closed/on.
Tony- I have the module, you may have the cased teradac. But I use this for connections and it works. LRCK->D1/LRCK, Data->D2/Data, SCLK->BCK, no ground connection.
I made a little lm7802 ps @ 4.8v for the teradac/pc end and used the lcdps @5.0v in the dac case to power the teleporters.
After reading some threads I set the SW1 #5 and #8 on, SW2 #5 and #8 on, all other switches off. I now can use the teradac usb-i2s converter without the constant dropouts I had before. In the past the teradac was unusable via i2s. I could use it with the spdif out but the i2s sounds better. The dac will still drop the signal occasionally but is usable. SQ is very close the the shigaclone transport when using the i2s connection on the teradac.
Old 10th April 2012, 05:08 PM   #178
Many thanks Bikerboy, that's just the information I was after!
Regarding the SW switches, I'm using a Dual-Mono Buffalo II so I'm not quite sure how this translates, maybe Brian will have the answer. It's reassuring to know the Teralink's I2S output works though.
My Teradac started out as a cased one but I've modified it quite a bit -
(Sorry we're drifting a bit off-topic here...)
Old 10th April 2012, 05:09 PM   #179
Default Teleporters
Double post sorry
Old 19th April 2012, 11:45 AM   #180
Question Jitter
How much jitter add the Teleporter?
Introducing the bit "Teleporter"Hide this!Advertise here!
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 11:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 06:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 06:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 08:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 01:14 AM
