#151 |
Sure I have a draft of it done, and Brian is just reviewing it before posting it.
If you are not confident wait for the manual before starting work.
Less pulp more juice Twisted Pear Audio. |
#152 |
So I have the DIP switch all four positions "off" for the transmitter & all four positions "on" for the receiver, attached pic (where was jumpers now is the transmiter), it's OK?
#153 |
Yup, it's just that easy.
Twisted Pear Audio |
#154 |
Yeah, thanks again Brian
![]() I have in mind to power separately both Teleporters, it's necessary a very good shunt regulatort or simply a LM317? Last edited by merlin el mago; 2nd April 2012 at 02:21 PM. |
#155 | |
Even LM7805 is fine.The supply range on the Teleporter is pretty flexible. 4-8V should be perfectly fine. :EDIT: 9V may be on the high side - looking at the VREG junction temp. I would recommend 4-6V if you can do it and about 8V max. I will double check this when I get home later.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 2nd April 2012 at 05:22 PM. |
#156 |
Attached Sidecar pic, I believe:
PCM Teleporter receiver - Sidecar bit clock - BCK word clock - D1/LRCK data - D2/DATA DSD bit clock - BCK data left - D1/LRCK data right - D2/DATA It's OK |
#157 |
Yes that is the correct signal order for PCM and DSD.
#158 | |
Thank you |
#159 |
Yes 8V is as high as I would recommend. You might be able to get away with 9 or more but I wouldn't push it.
#160 |
Thanks Russ, just connected the Teleporter with the BIII, now I have to start the most critical part: taking I2S from my CEC TL1 transport.
It's possible if using I2S avoid the dropouts due to connect separately the clock? |
| Thread Tools | Search this Thread |
| Introducing: "Thesis" | tresch | Multi-Way | 13 | 13th October 2009 10:49 PM |
| THX for introducing "PC Based" | soundcheck | PC Based | 3 | 21st August 2009 05:56 PM |
| Introducing "Mork" : part 1 | Andy G | Multi-Way | 4 | 19th August 2008 05:11 PM |
| Bit of history.."Magic Brain" record changer | redrabbit | Analogue Source | 0 | 10th February 2008 07:53 AM |
| Introducing: "Sauron" | Andy G | Multi-Way | 28 | 19th September 2007 12:14 AM |
