Introducing the bit "Teleporter" - Page 12 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 20th March 2012, 12:24 PM   #111
Russ White's Avatar
Send a message via Yahoo to Russ White
Teleporter can transport any TTL signal. It does not even have to be PCM. Any signal from DC to 125Mhz on each channel.
Sure you can drive two DACs in one chassis from one receiving Teleporter.
Less pulp more juice Twisted Pear Audio.
Old 20th March 2012, 05:50 PM   #112
avr300 is offline avr300  Denmark
avr300's Avatar
I don't think it was the question.
Also can 1 teleporter transmitter drive 2 recievers simultaneously, like in a hypothetical case where it needs to feed two Buffalos in dual mono mode, but for whatever reason two buffalo needs to be physically seperated considerably more than 10cm that I2S connection needs to be ?
Old 20th March 2012, 07:49 PM   #113
rdk845 is offline rdk845  United States
Thanks for the reply Russ.
avr300 is right.
What I meant was whether 1 transmitting telepoter can drive 2 receiving teleporter simultaneously, where each receving teleporter driving 1 DAC, say in dual mono mode. This is not going to happen often, but if whatever reason the I2S connection from telepoter to the DACs has to be much longer than ideal 10cm or less, can I use 1 receving teleporter for each DAC?
Old 21st March 2012, 12:14 PM   #114
Russ White's Avatar
Sorry - answered without thoroughly reading the question. My fault.
Because the transmitter would see half the impedance I think I would prefer to use two pairs.
Cheers!
Russ
Old 27th March 2012, 06:04 PM   #115
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Might get to try the Teleporter soon, but need to know
what the switches do and I see there are eight input/output
holes. I'd guess each pair of holes is for ground + signal pair?
Old 27th March 2012, 06:30 PM   #116
neb001 is offline neb001  United States
It uses differential signals:
Because each channel of the Teleporter uses differential signals, with no signal ground connection, it also provides galvanic ground isolation between source and destination components, eliminating ground noise issues.
Old 27th March 2012, 06:46 PM   #117
Russ White's Avatar
On one end there are differential signals, and on the TTL end there are TTL signals. I will write a manual very soon.
Old 28th March 2012, 02:04 AM   #118
Just yesterday I found in my mail an envelope with 2 pieces of Teleporter.
If you did not order yours, do it now before they're gone. Yes, they are so good ! Teleporter does exactly what it is designed to and even more. Those little gizmos are small enough to fit anywhere. Tested for 15 yards over regular, unshielded CAT5 and they work like a charm. I can't imagine how I lived without Teleporter before. Just forget about SPDiF - Teleporter is the future ;-) Being picky I could ask for a little smd led on board to indicate operation and some headers added to the kit. Otherwise - top notch.
Old 28th March 2012, 03:30 AM   #119
Russ White's Avatar
Excellent report and feedback. I am glad you find them satisfactory.
Old 28th March 2012, 09:17 PM   #120
NicMac is offline NicMac  Italy
NicMac's Avatar
Got mine today!
I hope these will become the beginning of "lossless" digital audio transfer
To bad they don't take the quality RJ45 receptacles from Neutrik that I have: different pitch and alignment
Anyway - I can't wait to try them!
Nic
Introducing: "Thesis" tresch Multi-Way 13 13th October 2009 10:49 PM
THX for introducing "PC Based" soundcheck PC Based 3 21st August 2009 05:56 PM
Introducing "Mork" : part 1 Andy G Multi-Way 4 19th August 2008 05:11 PM
Bit of history.."Magic Brain" record changer redrabbit Analogue Source 0 10th February 2008 07:53 AM
Introducing: "Sauron" Andy G Multi-Way 28 19th September 2007 12:14 AM
Copyright 1999-2017 diyAudio
