| Twisted Pear Superior quality electronic kits |
Russ and Brian,
First thanks for all you guys do for us. I have recently noticed, that there is now the beginning of what I suspect may become a trend for computer based music systems: the use of a high sample rate compatible NOS DAC, with computer playback software capable of applying oversampling/filter(s). With a computer interface capable of 24-32/384-768 sample rates, and an NOS DAC with equal capabilities, the possibilities seem really interesting, as one could try many different oversampling and filtering approaches, all implemented in the playback software. This approach provides many advantages, as the computer can have plenty of processing power to use complex oversampling/filtering, and it would be easy to apply many different approaches, while being able to keep the same NOS DAC hardware. Now I know you guys probably have your hands full of projects-but I would love to see a NOS DAC module from you, and since you already have a high resolution USB interface in the works, it might make sense to pair it with a NOS, I2S input DAC (perhaps 1704 based, with a new version of the Legato tweaked to match). Just something to ponder... |
#2 |
May I ask some questions?
1. Why you say "computer playback software capable of applying oversampling/filter(s)"? I thought oversampling was a way of translating multi-bit tracks into 1 bit stream to use sigma-delta converters. If you increase sample rate before that step and feed a R-2R ladder converter with a 24 word bit track, I would call it up-sampling (although both means digital filtering). Am I thinking something wrong? 2. Which anti-imaging analog filter in the I/V stage would you use? I think you would need at least a low-pass filter at 768 kHz, right? 3. PCM1704 has 20-Bi or 24-Bi INPUT AUDIO DATA WORD. Suppose I have a 16 bit audio track in my hard-disk. 3.a) Do I need to convert it into 20 bit word? 3.b) Does that conversion demand a complex algorithm? Can we just do a word bit dislocation with no complex calculations or approximation? 3.c) Can the USB to i2s hardware do that? Does that introduce jitter? 4. Suppose I want to play a 16 bit and 44 kHz audio track without computer bases pre-processed up-sampling digital filter. If my anti-imaging analog filter cuts at 768 kHz, would the analog output present signal images in the 88 KHz to 768 kHz region? Would that images waste power on the amplifiers* or affect the transducers? 5. What is the cut-off frequency Legato 3 and IVY-III low-pass filters? 6. What do you have in mind related to the master clock? COD or Opus slaved approach (perhaps with the USB to i2s asynchronous converter as master clock)? Maybe a Secure Digital card transport? On the one hand, I agree that would be an ultimate experimenter kit. No over-sampling digital filter for sigma-delta converter, up-sampling digital filter for R-2R ladder converter and perhaps no anti-imaging analog filter at all, all in the same hardware. It looks interesting. On the other hand, you are asking Russ and Brian to build a Wadia 922 decoding computers... Okay, except Legato I/V stage differs from swift-current I/V stage... * Suppose I do not have a class-A amplifier with shunt power supplies "always sinking" amplifier and that such amplifier has enough slew-rate to reproduce such high frequencies... Last edited by jgazal; 11th September 2011 at 05:14 PM. |
#3 | |
#4 | |
![]() I wonder if the BUS bitrate does mean a significant restraint to a digital filter. Certainly your computer allows different, new and perhaps more efficient algorithms, but it will be limited by your USB to i2S bus bitrate. Suppose I have an inefficient algorithm and low processing DSP working synchronous at a higher "revolution" (sample rate) than your bus bitrate. Maybe that higher "loop" in your inefficient algorithm gives a better result (more precise approximation) than a more efficient algorithm processed asynchronous with lower loop (your bus bitrate). What do you think? p.s.: I suppose audio signal bandwidth is identical in both arrangements. I am thinking about the filter response above 22 kHz. |
#5 |
TPA's forthcoming USB-I2S converter is rumored to work up to 32/384, for the 1704 we would only then use 24/384.
"Certainly your computer allows different, new and perhaps more efficient algorithms, but it will be limited by your USB to i2S bus bitrate. " A 352.8 sample rate allows for 8x oversampling filters to be applied to 44.1 sources. At this rate, it should be possible to do very good filtering, and push problems way up in frequency to where they will be inaudible. I believe the 1704 can handle up to 768 KHz in. Those who feel doing D/A at rates much higher than this are going to be happier with an ESS style DAC operating in the MHz range. If someone wants higher rates (705.6 and 768), one will have to develop a USB-I2S interface capable of handling the hiher rates-certainly USB 2 HS has plenty of bandwidth to handle higher oversampling rates for only 2 channels. Unfortunately, I have neither the knowledge, experience, or skills to develop a DAC board to do this myself, and this is why I suggested it here, and I just wanted to start a discussion on one approach which might suit computer based playback really well. |
#6 | ||
As I see, with 1-bit sigma-delta demodulators you need a certain number of cycles to achieve zero analog level and that add out-of-band high-frequency noise. Quote:
| Valab external dac will work with my nos dac? | noyan | Digital Line Level | 2 | 9th May 2010 04:17 PM |
| Nos Dac ves oversample DAC | Hyldal | Digital Source | 23 | 19th December 2009 09:47 PM |
| nos dac or emu1212m | umut1001 | Digital Source | 0 | 8th January 2009 09:19 PM |
| An idea! Fully balanced TDA1541A DAC idea. Please comment! | cartman | Digital Source | 8 | 17th July 2007 08:18 AM |
| Wtb: Nos Dac | crossroads | Swap Meet | 0 | 29th July 2006 10:35 PM |
| Page generated in 0.16345 seconds (90.39% PHP - 9.61% MySQL) with 10 queries |
