S/PDIF 4:1 MUX/Receiver Module - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 7th December 2011, 07:11 AM   #21
I'm finally getting around to building my Buffalo 2. I have all the parts I need except one: the S/PDIF 4:1 reciever MUX.
In going through the posts, it was in July that it was mentioned a new one for the Buffalo 2 would soon be available as the one in the web store has been out of stock now for a very very long while.
So... the question arises... When might it be available?
My build is dependant on multiple inputs and it would not be very cost effective (read that it would be very prohibitve) if I had to scrap my dual mono set up for a Buffalo 3 setup of like configuration. It would be extremely disappointing if I could not obtain the reciever. Please don't tell me it is now NLA
JD
Old 7th December 2011, 07:30 AM   #22
Hi JD,
I am also have been waiting for one for a very long time. The good news is it is coming soon (I hope). Please follow this link to see the reply from Russ few days ago!
S/PDIF 4:1 MUX/Receiver Availability - General Questions - Twisted Pear Audio Support
Hope this helps,
Milton
Old 7th December 2011, 08:03 AM   #23
It would be great if we can get board layout size as I am readying a chassis. That way when it does become available, I can just bolt it in and go.
It's been about a full year since I got my dual mono Buff2's Lagatos and power supplies. The sooner the Mux's are shipping the better. I'd even settle for the original one at this point, as that is what has been holding up my build for the last 1/2 year.
The link seems like a good news / bad news bit of information. Would really like the board sooner than into 2012.
JD
Originally Posted by audiblesound View Post
Hi JD,
Hope this helps,
Milton
Old 7th December 2011, 01:29 PM   #24
Russ White's Avatar
Send a message via Yahoo to Russ White
I am working very actively on it. Unfortunately crucial end of year real-job work has taken up all but sleeping time lately.
I have a prototype on my desk. Brian and I found a couple of hardware tweaks we need to make, but I will get those PCBs very soon. In the mean time I just need to finish writing the firmware.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 7th December 2011, 01:36 PM   #25
BrianDonegan's Avatar
The board size is the standard 2x3.3 (http://www.twistedpearaudio.com/docs...rd_Outline.pdf).
Old 7th December 2011, 06:18 PM   #26
Thanks Brian. you wouldn't happen to have a board diagram where the pin outs are by chance? That way I can also plan for the orientation of the board relative to the other boards in the chassis.... ie inputs, outputs, voltage in etc...
JD
Old 7th December 2011, 06:42 PM   #27
They are likely to move with the revision, so we should probably hold off on that until Russ has the changes made.
Old 19th December 2011, 03:04 AM   #28
Brett's Avatar
I'm up for one of these when available too.
I'll be using an ADC for my analogue sources into one input, other SPDIF sources into others, SPDIF out to my digital xover and hopefully I2C into one of your Buffalo DACs for headphones, for the digital sources at least.
Also looking forward to the ES based ADC for later.
Old 20th January 2012, 09:56 PM   #29
is it mux yet?
JD
Old 25th January 2012, 05:13 PM   #30
word?
JD
FS TP NEW S/PDIF (WM8804) Receiver Module (Assembled and Tested) merlin el mago Swap Meet 3 20th October 2011 09:13 PM
WTT TP S/PDIF transceiver for S/PDIF 4:1 MUX/Receiver Module merlin el mago Swap Meet 0 28th June 2011 11:48 AM
WTB T.P.A S/PDIF 4:1 MUX/Receiver Board Zero Cool Swap Meet 4 24th June 2011 10:53 PM
I2S-S/PDIF 2:1 Mux Receiver merlin el mago Twisted Pear 7 2nd April 2011 07:04 PM
Twisted Pear - S/PDIF 4:1 MUX/Receiver Module (new, unused) n_maher Swap Meet 3 19th February 2009 05:57 PM
Copyright 1999-2017 diyAudio
