Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 7th February 2012, 10:13 PM   #941
Can two side cars be run in series? I'd like the option to switch DSD and I2S? I thought I'd seen the answer in the BIII thread but I could not find it.
Old 9th February 2012, 08:16 AM   #942
regal is offline regal  United States
Any -60dB THD numbers or FFT plot?
Old 9th February 2012, 12:07 PM   #943
Russ White's Avatar
Send a message via Yahoo to Russ White
No, what you would want there is a TTL MUX at the PCM/DSD side of the sidecar.
That's one of the things we have on the list to get done soon.
Less pulp more juice Twisted Pear Audio.
Old 11th February 2012, 09:09 AM   #944
angcl is offline angcl  Singapore
Hi Russ and Brain ,
How is the small board with 4-position rotary switch connect to the Buffalo's I/O expansion header with a four wire connector ?
Any connection diagram ?
Old 11th February 2012, 03:21 PM   #945
LeonvB is offline LeonvB  Netherlands
Described in the manual: pins 2+4+6+8.
Old 12th February 2012, 03:28 AM   #946
thanks
Old 15th February 2012, 02:25 PM   #947
Hello folks
If I want to use dual BIII´s and single Legato 3, do I need the inverting "L to R bridges" described by Rosendorfer in the dual BII, single Legato thread?
http://www.diyaudio.com/forums/attac...1legato_06.jpg
best
Leif
Norway
Old 15th February 2012, 10:38 PM   #948
Russ,
Can you give me the dimensions of the planned TTL MUX board. I want to leave enough room for it in the case I am putting together.
Old 16th February 2012, 12:06 AM   #949
BrianDonegan's Avatar
Russ,
It's not that far along, but it should not be any larger than one of our 2"x3.3" modules.
Twisted Pear Audio
Old 8th March 2012, 07:27 PM   #950
Hi - I'm building my first buffalo - a 32S - I can't find this anywhere -- can someone tell me what size and kind of wire to use from the TPA PSUs to the main board ... and from the main board to the RCA/BNC outputs - Sorry for the newbie question -THANK YOU, Kind Regards, dean
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Page generated in 0.07972 seconds (73.23% PHP - 26.77% MySQL) with 11 queries
