| Twisted Pear Superior quality electronic kits |
#731 | |
#732 | |
If I configure BIII outputs to 8ch and play 2ch source only dynamic range will suffer? BIII inputs shall be configured in the same way as outputs? What are drawbacks of not paralleling inputs of the dac? Can I use XLR to RCA converters to connect dac outputs to SE amplifier? Thanks in any way.
If for pristine and pure adoration - it's diyAudio dedication! Last edited by AndriyOL; 13th October 2011 at 06:23 PM. |
#733 |
Your "I2S" does not sound like any I have ever seen. What is the source?
Less pulp more juice Twisted Pear Audio. |
#734 |
The source is PC sound card with SC4382 dac. I sent you a pm Russ with my connection problem description.
However I have anoher card with Phillips UDA1328 dac, but it's only 6ch PCM input. Can I use something like this http://www.fullcompass.com/product/297984.html to connect BIII to my SE amp?
If for pristine and pure adoration - it's diyAudio dedication! Last edited by AndriyOL; 13th October 2011 at 06:43 PM. |
#735 |
- GND is connected to the signal ground. I'm sure your I2S input has a ground pin hidden somewhere.
- Noise will likely be higher. - You can use the SE outputs of the I/V stage to connect your SE amplifier. |
#736 | |
- do you mean in case when dac inputs are not paralleled like outputs? - I'm aware of that. What about this converter?
If for pristine and pure adoration - it's diyAudio dedication! |
#737 |
He answered that. You can use a "converter" (its not converting anything) like that at the DAC outputs, but the noise will be higher. It is far from ideal.
#738 |
Russ,
What input impedance range amplifier should have so the DAC will act as a voltage source? How to measure amplifier's input impedance if there is an input capacitor, just behind it?
#739 |
Banned
Any amplifier will have a sufficiently high input impedance to make the output of the DAC chip act as a voltage source. Another way of looking at this is that you need an input impedance of around zero ohms for it to *not* act as a voltage source (ie a current source) and nobody makes amps like that.
#740 |
Banned
I'd like to report this question - it got lost in a deep discussion about ribbon connectors.
=============================================== I'm interested in any opinions from BIII users as to the exact meanings and effects of some of the switch settings. I'm only using SPDIF input, mostly red book. So what effect do these settings have, or are they even relevant? - Quantizer setting - Differential mode - FIR Roll off (and what does this filter do exactly?) |
| Legato or IVY III outputs for Buffalo II? | natzev_i | Twisted Pear | 272 | 21st March 2011 08:08 PM |
| Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 06:47 AM |
| How much compromise, small EQ'ed sub | audiobomber | Subwoofers | 10 | 15th March 2007 09:46 PM |
| Considering a compromise | mashaffer | Full Range | 7 | 14th May 2006 11:45 PM |
| OB subs: Best compromise? | MtnBob | Subwoofers | 13 | 26th May 2004 02:19 PM |
