Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 16th September 2011, 09:55 PM   #571
Are your fellows drunk ? Come on keep working.
Old 16th September 2011, 10:30 PM   #572
Assuming you had both lying around would you recommend the IVY-III over the Legato for use with a Sympatico amp? I noticed in the integration guide that it mentions the IVY-III measures better.
Old 17th September 2011, 08:24 AM   #573
tyk is offline tyk
Originally Posted by Russ White View Post
"B" is connected to the base of the trigger transistor.
You can connect the supply to ~5V the relays are active when you pull up "B" via a switch on any other mechanism.
I will post the schematic later today. There is not much to it.
The integration guide explains the use of sidecar.
Thank you for your information.
Old 17th September 2011, 11:33 AM   #574
Buffalo III DAC Integration Guide 1.0.2 says that for stereo mode best measured performance is reached when the quantizer is set to 6 bits. Isn't it a typo? Is it better to use 6 bits instead of 9? Thank you.
Old 17th September 2011, 11:47 AM   #575
What is better to power BIII 1/2 of LCDPS V.2.0 or Placid HD V.1.0?
Old 17th September 2011, 12:53 PM   #576
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes it measures better to use 6 bits instead of 9. But use whatever you like best.
Less pulp more juice Twisted Pear Audio.
Old 17th September 2011, 12:58 PM   #577
Russ White's Avatar
Both have advantages.
The advantage of the LCDPS is simplicity, ease of use, and lower total current draw.
The advantage of Placid HD is lower noise and both better line and load regulation.
The nice thing about Placid HD is that it gives you the best basis to start. every bit of noise reduction you can add prior to the tridents does help. Also the shunt reg is better at isolating regulators from each other.
Old 17th September 2011, 01:04 PM   #578
Russ White's Avatar
Both work marvelously. I would personally (and do personally) use both.
The IVY-III does measure better, and is much easier to build and to adjust output levels etc. So the average builder can't go wrong with IVY-III. It sounds awesome.
Legato sounds excellent and only measures very slightly worse than IVY-III (only dynamic range is worse - THD is almost identical) but is not necessarily the best choice for beginners. It not as simple to build or adjust.
Old 17th September 2011, 07:12 PM   #579
Russ, thank you.
Old 19th September 2011, 03:36 AM   #580
angcl is offline angcl  Singapore
Hi Russ,
I want to connect to unbalanced tube iv stage ,understand the BIII is balanced output .
just using +v & ground ?
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
