| Twisted Pear Superior quality electronic kits |
#561 |
I am running stock Placid and Placid BP with two of each running a dual mono set up with Trident upgrades on the BII Legato 2 without buffer and three Ventus ( only driving high impedance amplifier unbalanced.) I can touch the fins indefinitely,but can not hold the flat part of the heat sink that the device is connected to for more than a second. The current setting pots needed to be adjusted several times (shunting 60 ma) as things heated up but now seem stable continuously on.
Not having an infra red temp meter is the casual test to grab the fins or the flat section? I know I am at the edge and plan to upgrade to HD versions, but notice that the heat sinks are the same size. I have some much larger heat sinks but the footprint of the HD-BP will not accommodate them. |
#562 |
For those interested in clock experiments with ESS9018, there is a new thread:
ESS9018 - try new, try more... |
#563 |
Banned
I also posted a new thread Buffalo III DAC with tube output stage
#564 |
Hello,
I received a sidecar module today. Where can I find schematic of sidecar? or explanation for relay power supply I'm just confused how to treat B ( on VD/B/GND side). |
#565 |
I want to tap S/PDIF out from PCM2705 (Airport Express G) to 4-in-1 switch and then BIII.
May I ask the S/PDIF signal from PCM2705 (pin 5,6) is TTL Level? So that I must change the resistor on the 4-in-1 board from 75 ohm to 10k ohm according to manual? Thanks! |
#566 |
Why don't you just pull up it's data sheet?
Less pulp more juice Twisted Pear Audio. |
#567 | |
You can connect the supply to ~5V the relays are active when you pull up "B" via a switch on any other mechanism. I will post the schematic later today. There is not much to it. ![]() The integration guide explains the use of sidecar.
#568 | |
#569 |
Many people might have read the message "Thanks Brian!" on the back side of BIII board. Near the printing, there are three through-holes.
Today, I could well realize the purpose of the holes. I much appreciated Russ' well-considered pattern design that meets various requirements by users. |
#570 | |
| Legato or IVY III outputs for Buffalo II? | natzev_i | Twisted Pear | 272 | 21st March 2011 08:08 PM |
| Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 06:47 AM |
| How much compromise, small EQ'ed sub | audiobomber | Subwoofers | 10 | 15th March 2007 09:46 PM |
| Considering a compromise | mashaffer | Full Range | 7 | 14th May 2006 11:45 PM |
| OB subs: Best compromise? | MtnBob | Subwoofers | 13 | 26th May 2004 02:19 PM |
