Buffalo III - flexibility without compromise. - Page 54 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 8th September 2011, 10:58 AM   #531
Bunpei is offline Bunpei  Japan
Default Stacking two BII or BIII board
I received multiple BIII board kits and looked at bare boards with neither pin headers nor terminal blocks. This looks very flat.
The impression gave me a such idea of "Stacking two BIII boards in a vertical direction and making DAC chip +, - outputs in parallel for a simple stereo configuration with just one I/V module."
This combination would bring 8 DAC output sections for each L/R channel.
Has anyone experimented this configuration and compared with a conventional dual mono?
Old 8th September 2011, 12:12 PM   #532
Russ White's Avatar
Send a message via Yahoo to Russ White
It should work just fine (though i have not tried it exactly like you say). This would not be dual mono, but would be stereo with 8 DACs in parallel.
I am not sure I would feel compelled to do so.
You will also need to think about DAC addresses etc, you would want special firmware for that.
I would say give it try if you feel like it.
Just keep in mind power requirements and the fact that your I/V stage will have double the output swing unless you adjust it.
Less pulp more juice Twisted Pear Audio.
Old 8th September 2011, 02:28 PM   #533
rx7mark is offline rx7mark  United States
Bunpei,
Take a look at this thread about using 2 BII's with a single Legato. This should work the same for 2 BIII's with a single Legato, with the only new issue being the proposed stacking.
Buffallo Dual Mono 1 Legato
Mark
Old 8th September 2011, 04:23 PM   #534
glt is offline glt  United States
Would variations in the AVCC module be an issue?
www.hifiduino.wordpress.com
Old 8th September 2011, 05:08 PM   #535
Russ White's Avatar
No because they would sum, wouldn't matter in the least.
Old 8th September 2011, 09:22 PM   #536
Originally Posted by BrianDonegan View Post
There will be a single S/PDIF module sometime soon. Basically a single channel of the 4-Input module (trafo, comparator, etc).
Hello, Brian. Can you tell me when a single S/PDIF module will be available? Thank you.
Old 9th September 2011, 12:47 PM   #537
Hi Russ,
Could you equip BIII boards ordered 03.09.2011 with new Crystek CCHD-575 devices?
Regards.
If for pristine and pure adoration - it's diyAudio dedication!
Old 9th September 2011, 09:53 PM   #538
Russ White's Avatar
Originally Posted by AndriyOL View Post
Hi Russ,
Regards.
We are still evaluating that clock. Even if we were ready to use them Crystek is not making them in the quantity we need yet. Plus those modules are already built. So the short answer is no.
Old 9th September 2011, 09:54 PM   #539
BrianDonegan's Avatar
Not sure yet. The boards have not been submitted for mfg yet.
Old 9th September 2011, 10:13 PM   #540
Russ White's Avatar
In the next month or so. I am planning on ordering them soon, then we just need to give them a quick test.
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
