| Twisted Pear Superior quality electronic kits |
#521 |
I am quite sure I have mentioned that all you have to do is request it recently.
Less pulp more juice Twisted Pear Audio. |
#522 | |
I just got it today at once that datasheet following Takaji usefully advice/info. Nice! Last edited by Coris; 2nd September 2011 at 05:31 PM. |
#523 |
Brought my OPus Double mono tonight for the club. I have done some mods. I use Silk volumentrafos and a shunt regulated Lars Vester buffer capable of driving 50 ohms. The best dac ever in the club.
![]() ![]() Sorry for OT. |
#524 |
Hi Russ
I can see in the old manual of Buffalo this: "AVCC should be in the range of 3.3V +/- 5%. Voltage outside this range may result in damage the DAC." I can see in the new manual of Buffalo 3 the follow: "You might note that we use an AVCC voltage that is slightly higher than 3.3VDC. This helps us achieve slightly better dynamic range." In "Technical Details of the Sabre Audio DAC" I can find this: "The Sabre DAC operates from nominally 3.3v for its analog section and nominally 1.2v for its digital section. The analog section power supply is flexible: it will operate from 4.0v down to1.8v with little performance degradation. .................................................. ............................... "This configuration allows >132dB of DNR to be typically reached. NOTE: With 4.0V power supply greater than 133dB can be achieved." Is destructive more than 3,3v AVCC or not? The DAC can in fact tolerate up to 4v on AVCC? What could be a safe level in your opinion? Can you comment a little, and maybe precise exactly what is the AVCC level you have set up in the Buffalo 3? Thanks. Last edited by Coris; 2nd September 2011 at 09:12 PM. |
#525 |
This just reflects a progression of knowledge passed on to me from ESS since that Buffalo manual nothing more. Early data sheets said that AVCC should be 3.3V. What we found with Buffalo II and III was that 3.4 to 3.6V was a sweet spot, lower or higher gave mixed results. Certainly up to 4V is safe , but such voltage will require some tweaking of output stages to compensate.
Really if your questions are about the chip itself, they should be directed to ESS.
Less pulp more juice Twisted Pear Audio. Last edited by Russ White; 3rd September 2011 at 03:53 AM. |
#526 | |
#527 | |
I was not worried over that, only trying to explain that my knowledge of the chip has its limits as well. I regularly have the ask ESS questions myself.
#528 |
Banned
My Buffalo III arrived a couple of days ago. While I was waiting for it to arrive I'd built the rest - PSUs, tube output stage, etc. So it only took a few hours to get it up and running.
I plan to post a separate thread with build pics, etc But just wanted to say that it sounds awesome.. |
#529 | |
Thanks |
#530 |
Banned
Yes I will reveal all in upcoming thread.
| Legato or IVY III outputs for Buffalo II? | natzev_i | Twisted Pear | 272 | 21st March 2011 08:08 PM |
| Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 06:47 AM |
| How much compromise, small EQ'ed sub | audiobomber | Subwoofers | 10 | 15th March 2007 09:46 PM |
| Considering a compromise | mashaffer | Full Range | 7 | 14th May 2006 11:45 PM |
| OB subs: Best compromise? | MtnBob | Subwoofers | 13 | 26th May 2004 02:19 PM |
