Buffalo III - flexibility without compromise. - Page 52 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 1st September 2011, 07:20 PM   #511
Takaji is offline Takaji  Canada
Originally Posted by Russ White View Post
Takij, you need to post things like this on our support forum please. But to quickly answer your question. You will want large heatsinks for that. And you will need to double check if you can adjust to that current (I have not tried yet). If you can't I can explain to you how to get there. I would use a 9V 30-50VA transformer.
Thanks Russ, noted. I will use the support forum in the future. Thank you for the info!
Old 1st September 2011, 10:45 PM   #512
Good news folks.
I am testing AC2 with firmware designed for Buffalo III with the parts we will be stocking for the kit.
In my testing I found one small layout change I will make (already done) and as soon as those revised boards get here we should be able to offer it to you folks.
Highlights:
- Standard 4-bit parallel interface for displays
- 3 SPI inputs/outputs for displays or other hardware
- Super fast infinite write cycle FRAM for saving state, which is far faster and easier to use as well as more reliable than flash.
- Rotary encoder support with push button. Supports both optical and mechanical types.
- IR(RC5) remote support.
- 3.3V Level shifting for I2C for application that might require it.
- On board power supply with rectifier so you can supply either AC or DC voltage.
- Easy programming with the Femto USB programmable controller module.
The Femto controller module is removable from the AC2 for simple programming via USB.
I will create a GitHub account for AC2 code. People can use that code as-is or contribute code enhancements. There will also be a wiki for documentation.
Cheers!
Russ
So the Buffalo II is just for garbage before I have completed it !
Old 1st September 2011, 10:54 PM   #513
Duffy Moon's Avatar
I'm sure the AC2 will be able to control the BII as well. I expect BII firmware will be next.
Exciting news indeed. The AC2 has acquired almost legendary status. It's the "Duke Nukem Forever" of the DIY audio world (but more likely to live up to expectations).
In TP we trust.
Old 2nd September 2011, 12:45 AM   #514
Russ White's Avatar
Send a message via Yahoo to Russ White
Absolutely AC2 will support BII.
Less pulp more juice Twisted Pear Audio.
Old 2nd September 2011, 01:30 AM   #515
For anyone who is looking for the ES9018 DAC datasheet to do some tweaking with their BIIIs:
I spoke with Bryan at Shaw Electronics (shawelectronics.com), the US distributor for the chip... he said that 6 months ago the ES9018 datasheet was taken off the non-disclosure agreement list, so now you just have to request it and he will send it to you.
So, if you want the ES9018 DAC datasheet, kindly email Bryan at "bryan at shawelectronics dot com" and ask!
Old 2nd September 2011, 06:09 AM   #516
Coris is offline Coris  Norway
Coris's Avatar
Many, many thanks for this important information. I hope will work...
Old 2nd September 2011, 12:28 PM   #517
Russ White's Avatar
The datasheet has been available this way for quite some time. It has been mentioned before, but I am glad to have it said again.
Old 2nd September 2011, 12:32 PM   #518
Russ White's Avatar
In TP we trust.
It is interesting and kind of funny. I have been using AC1 and AC2 for quite a while now, it has not really been the design that has been the hold up. It really has been a logistical issue of finding good available kit components etc and having time to test the whole thing as a practical package.
I do regret the delay in getting it out to you guys, but hey better late than never.
Old 2nd September 2011, 12:33 PM   #519
Old 2nd September 2011, 03:21 PM   #520
The last mention of the ES9018 datasheet in this thread indicated that you still had to sign a non-disclosure agreement... good to see this is not needed anymore!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
