Buffalo III - flexibility without compromise. - Page 131 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 14th December 2013, 06:06 PM   #1301
Russ White's Avatar
Send a message via Yahoo to Russ White
The ground will naturally meet at the DAC, no need to do anything special. Just wire the Placid BP to the IVY.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 5th February 2014, 02:45 AM   #1302
Russ White's Avatar
I bet a lot of you might be interested in this:
http://www.diyaudio.com/forums/digit...tter-pear.html
Old 4th March 2014, 05:15 PM   #1303
Can I ask if/when there will be a next batch of Buffalo III 8 channel?
Old 4th March 2014, 09:48 PM   #1304
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
I have read the manual, but I still want to ask how sensitive is the board to supply voltage.
Can it work with a 6V battery?
I'm that guy who finds ways *not* to do things..
Old 5th March 2014, 08:52 AM   #1305
BrianDonegan's Avatar
Yes. I am working on getting them built now.
Old 6th March 2014, 04:28 PM   #1306
Nikitas's Avatar
Anybody knows?
Which parts are supplied directly from the onboard connector that can't take higher voltage? aren't the onboard regs taking care of the supplies for all the parts?
Old 6th March 2014, 04:36 PM   #1307
Anybody knows?
If you are using v3 Tridents and v2.1 AVCC, you can use a 6V supply without issues.
Old 6th March 2014, 04:45 PM   #1308
Default Well...
This is not as simple a question as you might think. A "6 volt" battery does not always supply 6 volts. With a full charge a battery will supply somewhat over its nominal voltage (how much will depend on the type of battery and its condition), and as it discharges the voltage will drop. To have a complete answer to your question, you will need to test the battery and record its real voltage under load, and see what its voltage range is from a full charge to its (nearly) discharged state. Once you know the range of voltages output by your battery, then you will need to ask what voltage range the onboard regulators will work with.
Old 6th March 2014, 07:47 PM   #1309
Russ White's Avatar
Brian is correct, and even a bit above that is ok. I would not exceed 6.25V without keeping a close eye on the AVCC module, it's shunting a lot of current.
As Barrows said - Make sure you take into account your peak voltage - which is often much higher than the nominal voltage.
Old 6th March 2014, 08:09 PM   #1310
Nikitas's Avatar
Thanks guys
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
