Buffalo III - flexibility without compromise. - Page 127 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 27th April 2013, 12:20 AM   #1261
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by shoom View Post
Hi Russ/Brian/Leon
just plugged in the new firmware update
reversed all switches
works fine
thanks
Excellent!
One other thing to mention is that if you use SPDIF selection you sould leave SW2 positions 1 and 2 open.
Also one side effect is that when using SPDIF4 the progress will be opposite what it was. For instance input 1 will actually be input 4 and input 4 will actually be input 1. This was not intentional, I just did not think about it until now. Still it will work just fine, just wire appropriately.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 27th April 2013, 05:13 PM   #1262
LeonvB is offline LeonvB  Netherlands
Exclamation New guide uploaded
Please beware that the current version of the guide (2.1.1) is based on the NEW firmware.
If you have a BIII with an old firmware and still use the 2.0.0 guide, everything should be fine. When using the old firmware with the new guide one should invert the ON/OFF values for SW1/SW2. The only exception is external switches: when using EXT_IO the corresponding switch on SW1 or SW2 should always be put in the OFF position.
Old 27th April 2013, 05:22 PM   #1263
shoom is offline shoom  Europe
‘’Please beware that the current version of the guide (2.1.1) is based on the NEW firmware.’’
Yup
That’s the version of the guide that I used to set up my BIII with the new firmware and I found everything clearly explained even for a novice like me.
Just a quick read through was all that was needed
Good job Leon
Old 1st May 2013, 01:11 AM   #1264
Hi Folks - I am putting together a BIII and when I purchased the parts I ordered a spdif4 card and a sidecar. I was originally planning to connect my music server via toslink, however I ordered a Amanero USB card recently and think that this might be a better way to go. My question is this: Should I used the spdif card and the sidecar or just connect the USB card directly to the BIII board?
Rick
Old 1st May 2013, 01:31 PM   #1265
Russ White's Avatar
I would suggest going direct PCM input if you plan on using that input exclusively. This allows you to wire optimally.
Old 1st May 2013, 06:09 PM   #1266
I'll do that.
RD
Old 15th May 2013, 06:13 PM   #1267
I am newbie here and planing to implement a buffalo iii DAC project and i am curious about LCD and control board... - is there any kit around I could use?
i can't do it myself, because have no skills in programming and arduino...
thank's for any answer
Old 16th May 2013, 03:32 AM   #1268
DQ828 is offline DQ828  Australia
DQ828's Avatar
If you are up to doing the electronics side, what you could do is follow one of the implementations that other DIY'ers are doing & use their code, generally everybody is willing to share. It's when you stray from there particular implementation that it becomes an issue. HiFiduino would be a great place to start looking.
Old 16th May 2013, 03:55 AM   #1269
There's also this one:
ES9018 I2C controller
Old 16th May 2013, 03:56 AM   #1270
As DQ suggested take a look at HiFiDuino Intro. A great primer for what is required.
INTRO | H i F i D U I N O
I went with a shield from Corpius. A shield is a second board that attaches to the Arduino board. He also offers his own version of a controller and provides easily configured code for your application. That and an I2C controller for the LCD significantly reduces the number of wires to run the LCD. My affiliation with Corpius is internet forum friend and paying customer for two of his shields. I am currently using his shield and code.
EDIT: bkdog beat me to posting but here is CE Designs site (Corpius).
Buffalo shield v1.1
electroFUN LTD: I2C LCD extra IO
This is how it looks wired ready to go with rotary encoder, I2C LCD extra IO board and IR receiver for Apple remote control for my BIII DAC. An Arduino UNO is under the shield.
Last edited by SCompRacer; 16th May 2013 at 04:11 AM. Reason: bkdog posted while I was composing
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
