Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 23rd November 2012, 09:56 PM   #1191
BrianDonegan's Avatar
1: Resistor installed?
2: What the voltage across the LEDs?
Twisted Pear Audio
Old 24th November 2012, 05:19 AM   #1192
c12mech is offline c12mech  United States
c12mech's Avatar
1: Resistor installed? It was the one with the kit. I measured it and it is 500R.
2: What the voltage across the LEDs? 0v across the LEDs. I also measured from ground to each corresponding pin on the back of the switch and there is no voltage on any of them either.
Old 24th November 2012, 01:38 PM   #1193
I think a couple pictures will help solve it.
Twisted Pear Audio
Old 24th November 2012, 01:45 PM   #1194
c12mech's Avatar
I will take some when I get home today. Anything specific that would help? I really hope that this something simple that I have overlooked.
Old 24th November 2012, 02:02 PM   #1195
Top and bottom of the board and connections to DAC.
Twisted Pear Audio
Old 24th November 2012, 03:30 PM   #1196
Russ White's Avatar
Send a message via Yahoo to Russ White
Also lets move support requests to the support forum. Thanks!
Less pulp more juice Twisted Pear Audio.
Old 26th November 2012, 02:50 PM   #1197
c12mech's Avatar
I found the problem, loose connection on one end of the ribbon cable to the switch, and it is fixed now. I just needed to not look at it for a day and go back with fresh eyes.
Now that the leds do light up they are very dim. Almost unnoticeable really. I will change the resistor and see what happens tonight.
If I have any more problems I will start a thread in the support forum Russ. I did not think of that when I originally asked the question.
Old 9th December 2012, 01:58 AM   #1198
Russ White's Avatar
necplusultra , please utilize our support forum.
Old 9th December 2012, 11:11 AM   #1199
c12mech's Avatar
I just finished this one for a member at head-fi. It sounds amazing and I would recommend it to anyone.
Old 9th December 2012, 08:39 PM   #1200
Hi Russ,
don't know what happened to my post here but I appropriately posted my issue on the tp support forum under the buffalo thread.
Hoping to get feedback
kind regards.
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2013 diyAudio
