Buffalo III - flexibility without compromise. - Page 118 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 31st August 2012, 12:12 PM   #1171
merlin el mago's Avatar
Ask Steve Slater of Apex Junior Apex Jr.Home Page
Old 31st August 2012, 02:43 PM   #1172
Can you say Audio?
What he said :-)
Old 1st September 2012, 01:20 PM   #1173
BrianDonegan's Avatar
Apexjr had some great deals. The real benefit to the Teflon/silver wire is that it solders very easily and the Teflon takes the heat without melting/pullback. I use it whenever possible
I also have some large spools of red/white/black 20 and 22g PVC wire for general wiring tasks.
Old 7th September 2012, 11:10 PM   #1174
RollE2k is offline RollE2k  Sweden
Is the Buffalo III mainboard, Legato 3.1 and the SPDIF input board stackable on top of each other straight from the box, or does it take some clever diy solution? i was thinking to also add sidecar..
Old 11th September 2012, 05:28 AM   #1175
Takaji is offline Takaji  Canada
Is there a way to install a headphone jack for active monitoring of the DAC without using an IVY board? I saw in a user's photos on another forum that they had a headphone jack in this configuration.
Currently I'm using 4x IVY boards for 8-channel output and a fifth IVY board for stereo output. I'm hoping I wouldn't have to add a 6th IVY board for this...?
Old 11th September 2012, 02:25 PM   #1176
Duffy Moon's Avatar
Can't you just tap the outputs of the IVY you use for stereo? You can go SE or (my preferred option) balanced.
You can even tap the Buffalo outputs directly, but it doesn't work as well (useful for testing though).
I'm sure all this is covered in the documentation.
Old 11th September 2012, 03:09 PM   #1177
Sharing the SE outputs between a headphones and a high-impedance load (amplifier) if the way to go.
Old 13th September 2012, 12:56 AM   #1178
Thank you!
Originally Posted by MisterRogers View Post
I still consider myself a noob - but I've been using ApexJr. 22 gauge teflon milspec. stranded with silver plating. Seems to work well and is easy to work with.
Gonna go with this - seems like a good price! Thank you.
Old 16th September 2012, 04:29 PM   #1179
B3 can go in Sinchronus mode with Metronome 24MHz oscilator or will be better other oscilator with other frecuency for B3 better operation (of course max. 50MHz that's the maximum external reference clock input frequency of the Metronome)?
Old 18th September 2012, 12:33 AM   #1180
Russ White's Avatar
Send a message via Yahoo to Russ White
Hey folks, check this out.
Buffalo III - SE
Less pulp more juice Twisted Pear Audio.
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
