Buffalo III - flexibility without compromise. - Page 117 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 25th August 2012, 10:50 PM   #1161
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by glt View Post
How is the toslink connected?
Iv'e been sleeping thanks Corpius.
I'm sure some of you dont sleep
Old 25th August 2012, 10:56 PM   #1162
DQ828's Avatar
Originally Posted by Russ White View Post
You have to make sure pin 6 and 8 are pulled up. (say with 10K) That is normally done by the controller. With a stock B3 this is done by the on-board controller. You your case you need to be sure *your* controller does the same thing, or do it externally.
Where exactly do I put the 10K resistor? Although with my relay switching implementation I assume I dont need it?
Old 25th August 2012, 10:59 PM   #1163
DQ828's Avatar
As for the TOSLINK module - you may need to check that you are getting a good signal out of it. If you have the voltage divider working correctly the output should be equivalent to the consumer level signals.
Also make sure that since you are using the voltage divider you terminate the SPDIF-4 input you are using for that signal at 75R just like the other consumer level inputs.
I'll check the signal, I am using a 75R.
Thanks for the help
Old 25th August 2012, 11:03 PM   #1164
DQ828's Avatar
Thanks. The spdif input for the sabre32 should be rock solid. One idea is to directly connect the toslink output to the input of the BIII and avoid all the "unnecessary" level conversion. One way to do this is to tap the ribbon cable. Another way is to solder to the pins at the bottom of the pin header
Originally Posted by LeonvB View Post
I would suggest using grid connectors to simply connect the pins the way you want them.
I'm not sure exactly what you mean but let me go & ponder, it is early & the brain is still hazy
The lock on the Spdif is rock solid
Old 26th August 2012, 08:53 AM   #1165
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Originally Posted by DQ828 View Post
I am switching on my Linkwitz ASP crossovers, that I use for my own speakers, that was a learning experience
There is also a Tinkerkit relay module you cannot see.
I am also switching my 2 amps & the BIII, all sequenced to avoid those awful noises, although I'll have to say the ASP's & BIII dont make really bad noises when switched off before amps, the MiniDSP I was using for the crossover made TERRIBLE noises come through the speakers if you got out of sequence. I remember one day accidentally switching off the MiniDSP first, the noise scared me SO MUCH, while my finger was still on the switch I switched it twice more, needed a good lay down after that
I imagine I may need help with the volume display as I'm not sure howI am going to make it work without removing the firmware chip.
Thanks again.
Right, now I remember that you where switching amps, BIII and cross-over in a certain sequence.
Displaying the correct volume is not that difficult, but I suggest taking this topic back to the TPA support forum.
Old 26th August 2012, 08:56 AM   #1166
Corpius's Avatar
Actually, I do sleep from time to time.
Old 27th August 2012, 01:19 AM   #1167
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes, please.
Less pulp more juice Twisted Pear Audio.
Old 29th August 2012, 07:25 PM   #1168
Takaji is offline Takaji  Canada
Finally finished developing my 2-8 channel switcher for 8-channel output; I'm now ready to begin the wiring between boards!
Can anyone recommend a decent hookup wire to use in wiring my BIII between the different components?
I'm by no means convinced that fancy wire will improve the sound, I am just looking for something that is aesthetically-pleasing, to highlight the quality of the build. I was thinking something silver-plated. Any recommendations are appreciated, thank you!
Old 30th August 2012, 01:48 PM   #1169
Can you say Audio?
I still consider myself a noob - but I've been using ApexJr. 22 gauge teflon milspec. stranded with silver plating. Seems to work well and is easy to work with.
Old 30th August 2012, 10:53 PM   #1170
DQ828's Avatar
where do you buy it from?
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
