Buffalo III - flexibility without compromise. - Page 114 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 7th August 2012, 02:21 AM   #1131
Default SPDIF in
My buffalo III DAC has been working well with the single SPDIF converter input and my M-Audio FW410 SPDIF out. I recently purchased a M-Audio Delta 1010 and hooked up the SPDIF out from that. Both lock and mute LEDs stay on and no sound comes out. The Delta 1010 SPDIF out works fine when run to my Wadia 860 so that seems to be OK. Any ideas what is going on here? The Buffalo is set up in stereo mode with one SPDIF input.
Thanks, Mike
Old 17th August 2012, 08:17 AM   #1132
greetings.
Does anyone know how to connect dual mono buf3 to the sidecar?
Old 22nd August 2012, 04:43 PM   #1133
goober5 is offline goober5  Canada
Default Comparison to Musical Fidelity
Hi
I would like to build a BIII with a Ligato but I'll have to get rid of my existing dac Musical fidelity KW DM25 due to domestic rules. Could some one with experience elaborate on how these two would compare before I commit? I use a AVC for a pre and a aleph J.
Old 24th August 2012, 12:12 PM   #1134
DQ828 is offline DQ828  Australia
DQ828's Avatar
At the moment I use the 4 way Switch module to select between sources as per the photo.
I want to use my Arduino to switch sources using the same inputs that the Switch Module uses being (pins B0=6 & B1=8) I have tried what I thought would work but it clearly didn't so I expect my understanding of how the switch Module works is defective
Can anyone advise me how I might do the switching with the Arduino via the Switch module input.
File Type: jpg 12-08-21 Arduino Motor Control01_4.JPG (619.7 KB, 288 views)
Old 24th August 2012, 12:45 PM   #1135
Dimdim is offline Dimdim  Greece
If I were you, I would ditch the switch and would go for a HiFiDuino implementation.
That way you would do away with both the source selection problem as well as the analog pot which you are using for volume control.
Old 24th August 2012, 09:16 PM   #1136
glt is offline glt  United States
I think that is just a 4-way spdif to ttl level converter. It is not a switch module. In Arduino you will need to program register 18 to select the corresponding spdif input pin
www.hifiduino.wordpress.com
Old 24th August 2012, 10:16 PM   #1137
DQ828's Avatar
This is the input selector I'm referring to, I was hoping to finish climbing my low tech mountain before climbing your high tech mountain
DimDim
I started this journey before I found out about HiFiduino & I would like to finish it, if nothing else I will learn lots on the way. I'm almost there, if my source switching had worked I only had 1 thing left to implement, the screen.
File Type: jpg 12-08-24 Arduino Source Select01_1.JPG (270.9 KB, 242 views)
Old 24th August 2012, 10:52 PM   #1138
Oh, I understand now. Basically it is a two bit switch: either pull the bit high or low with arduino. I just read your thread over at TPA and your logic is correct. If you use the level converter you need to connect GND from the level converter to GND on the i/o connector (I think pin4)
Old 24th August 2012, 10:55 PM   #1139
DQ828's Avatar
I did that but when I power up the Arduino all the lights on the BIII can on even thought it was turned off, which freaked me out
Old 25th August 2012, 03:06 AM   #1140
DQ828's Avatar
Iv'e done a bit of testing on the switch unit, I connected a voltage source to the power inputs of the switch module & then read the output pins that go to pin 6 & 8 on the BIII.
I expected to see the output pins vary from High to Low, I tested between the power ground & the output pins. The pins go low to ground but at no stage does a voltage show on the output pins, the reading I got went like this.
Input 1 No reading & No reading
Input 2 To Ground & No Reading
Input 3 No Reading & To Ground
Input 4 To Ground & To Ground
I haven't had a chance to test the BIII inputs
File Type: jpg 12-08-24 Arduino Source Select01_2.JPG (267.9 KB, 214 views)
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
