| Twisted Pear Superior quality electronic kits |
#1091 |
You can use any type of high-res USB-I2S converter and connect it either directly to the buffalo, or indirectly via sidecar-module (when you want to use additional spdif sources like you want to).
TwistedPear is also working on an own high res USB module, which will certainly be good: USB-Module Thread You can guess from the age of the thread, that it might take a while until it is available. |
#1092 |
Hi Russ
I've ordered the BIII kits today and I want to add a legato to my order, how can I do it? |
#1093 |
Just email Russ at orderstatus(Insert at)twisted..... and you can figure something out. Service is top notch.
#1094 |
Do it fast as they usually ship out very fast.
#1095 | |
Generally the easiest way to do this is a make a second order through the web site, choosing the least expensive shipping option. Just put a note in the PayPal order that you would like the orders combined. My order management software indicates when a customer has multiple orders pending, so it's easy for me to combine the orders and ship them together. I then refund any extra shipping charges through PayPal when I ship and know the final (actual) shipping cost.
Twisted Pear Audio |
#1096 |
Thanks Brian, will place the order now.
#1097 |
May i know whata the lock and mute Led for? Should i solder them in?
Thanks |
#1098 |
Just a sanity check before I order some parts. Do I need to use grounded or isolated connectors for inputs and outputs. I have been looking for it in the manual but not seeing it. Thanks.
#1099 |
Isolated as always.
#1100 |
That's what I thought. Thanks.
| Legato or IVY III outputs for Buffalo II? | natzev_i | Twisted Pear | 272 | 21st March 2011 08:08 PM |
| Buffalo Dac original vs Buffalo II | mrtakib | Digital Line Level | 7 | 24th August 2010 06:47 AM |
| How much compromise, small EQ'ed sub | audiobomber | Subwoofers | 10 | 15th March 2007 09:46 PM |
| Considering a compromise | mashaffer | Full Range | 7 | 14th May 2006 11:45 PM |
| OB subs: Best compromise? | MtnBob | Subwoofers | 13 | 26th May 2004 02:19 PM |
