Buffalo III - flexibility without compromise. - Page 107 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 19th April 2012, 10:20 AM   #1061
gwikse is offline gwikse  Norway
Originally Posted by Corpius View Post
No they are not. You just need a workaround :
Download all files and then rename them by removing the last 4 characters (.zip) from each file name. Then unzip the first file, the others will unzip automatically. I used 7zip for this, but windows standard zip will probably work just fine. I split them into multiple files because the file size exceeded the maximum allowed file size for uploading to the forum.
Most components in the design are grouped, but you can blow them up into smaller grouped items. Such a the side panels, front panel, back panel, volume control, placid HD etc.
Why dont you just share the model inside sketchup? The files can not be opened even after renaming and using 7zip so....
I do not see why ppl need to split and rename and .... archived files.
Here are links to my models uploaded to sketchup`s 3d warehouse.
Models by gwise - Google 3D Warehouse Search
Old 20th April 2012, 06:06 AM   #1062
Corpius is offline Corpius  Netherlands
Corpius's Avatar
Strange. With me it works just fine. I will take you advise and upload it to the 3d warehouse.
Btw I uses some of you models. They are really good. I only took time fot getting the hifi2000 chassis right and then used some of your models to populate it. All other boards inside just haveright size, but no components on them. Just an image.
Old 20th April 2012, 10:33 AM   #1063
Looking forward to looking closer at your project. Looks very professional
I will upload some more components. Most of them are in the B3 WIP model, but I`ll upload them seporately as well so that they are more easily found.
The components on the pcb`s are visual only, they are not accurate. I have made the models with 2d images as reference to where to place the parts. The mount holes derived from tpa`s board outlines are accurate though.
I hope you will all find the models useful.
Old 20th April 2012, 11:55 AM   #1064
Corpius's Avatar
Thanks. I tried to upload my model to the 3D warehouse, but it is to large. I'll remove all TPA boards and then it should be less then 10 MB.
Old 20th April 2012, 12:06 PM   #1065
Corpius's Avatar
Well I finally succeeded. Here's the link to the model:
Hifi2000 Slimline Corpius design by Corpius - Google 3D Warehouse
Old 20th April 2012, 09:40 PM   #1066
Looks great. Will you run dual mono in that large case?
Old 21st April 2012, 08:09 AM   #1067
Corpius's Avatar
Not at first. I will add 4 selectable inputs using at least one 75 ohm bnc connector, one AES/EBU input, one rca input (although it is not 75 ohm) and maybe a toslink. Next to the four spdif inputs I will add the teleporter/sidecar combo to take I2S directly from my CD-PRO2 transport. I`ll use the IVY I/V stage to have both single end and balanced output. To control the volume I`ll use a remote controlled motorpot and add a mute funtion to this circuit.
I`m not sure about adding a USB input, but when I choose to add a USB unput it must be able to take high res. signals, unlike the TPA usb receiver. Maybe something based on xmos like this. Then I also need another method to control all inputs, something like arduino or similar. All other suggestions are welcome here!
First I will focus on the version without USB, but when using such a large chassis it is inevitable extend the B3 later on.
Old 22nd April 2012, 08:47 PM   #1068
Takaji is offline Takaji  Canada
Personally, I'm using the exaU2I for high-res audio via I2S input, and then the S/PDIF input board for AES/EBU, TOSLINK, and S/PDIF.
I will have balanced and single-ended out, either 2-channel mode or 8-channel mode using 5 IVY boards. 2/8-channel mode will be selected via a custom-made relay board, controlled via Arduino.
Visual display will be via Arduino as well. I am currently working on a variant/upgraded version of HiFiDUINO in collaboration with the code's author.
Currently wiring up all the outputs, which is actually time-consuming then, I will finish the Arduino controller, make a circuit board for it, and design the front panel. Finally, the mockup will be finished!
Then I will get the front/back/top/bottom panels professionally-finished and call it complete.
I suggest to you that you use HiFiDUINO to control your audio, and use an Apple remote as well. Then you can avoid the whole motorised pot and controlling/building that.
Old 22nd April 2012, 09:17 PM   #1069
Corpius's Avatar
Yesterday I decided that I want to use HiFiDUINO for my DAC. Today I ordered the Arduino uno. Since you are also building the B3, the code should be suitable for my DAC to, but I might want to personalize it a bit. Who doesn't? I have some experience with the programming languages C# and VB. Since arduino is C# bases, this shouldn't be to much of a problem.
Perhaps you can answer this question: Since I am not a very experienced DIYer I'm going for the save and easy way building the DAC. Of course I want to use an external controller, but do not want to get lost in this. Would it be possible or harmful to remove the IC with the onboard firmware (multiple times) and fiddle a bit around with the external controller and put it back again when things turn out not to be working as intended?
Old 23rd April 2012, 01:20 PM   #1070
ccclapp is offline ccclapp  United States
Default Takaji, amazing, you solved the mystery!!
Takaji
Am I understanding you to say you've figured out how to build 2/8-ch B-III/EXAu2i receiving USB, s/pdif, AES etc? In addition with remote control source/volume switching and even display?
Amazing! I've been trying to do the same ( could simplify and exclude display and remote control, if necessary). I ve assembled b-III/exa w 4 x ivy on plywood, but can't figure you how to add other sources. I thought I could use sidecar and 4x spdif mux but am told by leonv it won't work w m-ch USB. I've asked for his recommended solution, but don't understand his answers and can't get further clarification.
I'm new to DIY, but have an audiophile retired EE helping me. Problem is I can't show him what the solution is.
Are you willing to give a roadmap for a newbie on how to add the spdif, etc inputs to a B-III/EXAu2i m-ch rig? Even if I have to omit display, do manual switching and omit/manual volume to simplify, that's ok. I just want to add other inputs (2-ch) to my 8-ch b-iii/ exa config.
I'm very sure now or in the future many people will want this mystery solved, as without it all users have to choose between single source USB in m-ch, or m-source in 2-ch (I know non USB sources will always be 2-ch).
Here are my questions:
1) are you willing to do some hand-holding?
2) if so a separate thread might be good. You could start one or add to mine on the topic here...
B-III: Remote control / lots of inputs / 8-ch volume??? - Buffalo DAC - Twisted Pear Audio Support
3) how hard is it to add additional sources to biii/exa? Does it require programming if manual switching/volume?
4) I'm happy to pay for your assistance and also to write up the process as a guide for others, if either helps motivate you to help
It's fabulous you've solved this mystery!!
Thanks!!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
