Buffalo III - flexibility without compromise. - Page 103 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 7th April 2012, 06:05 AM   #1021
Originally Posted by avr300 View Post
thanks alot
how many idependent psu that you need for buffalo dac if you want to feed as many independent psu to each section of the dac?
i am new to this dac. so my quick look at the guide, i think can use 5 separate psu:
- 3 separate psu for 3 trident
- and 2 separate psu for analog section.
anything else?
is there any information on the current draw of each section? as i would like to supply with CLC raw psu only to each section. any possible problem by using unregulated raw power supply?
thanks
erwin
Old 7th April 2012, 11:40 AM   #1022
merlin el mago's Avatar
Originally Posted by SCompRacer View Post
Good catch Leif. Thanks Russ! I attached a corrected image noting B4 in this post. I don't have the power to delete or change the image in my prior post but would encourage those who do to change it or delete it. Thanks!
Do I ground B4 to the chassis, VG on the Sidecar or a ground on the external I/O connector header?
I suppose pin 3 GND of the external I/O connector, Russ or Brian could you confirm?
Old 7th April 2012, 01:03 PM   #1023
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes GND at EXT-IO which is the same as VD GND or any of the power GNDs.
Less pulp more juice Twisted Pear Audio.
Old 7th April 2012, 01:50 PM   #1024
It's necessary to change R1 10K in Sidecar for R1 1 K in Sidecar?
Old 7th April 2012, 01:57 PM   #1025
Russ White's Avatar
It depends, if your driving it from ~5V the 10K will work fine. If your driving it from an LED spot (1.8V) you will definitely need something around 1K (even a bit less is ok)
Old 7th April 2012, 02:59 PM   #1026
A pic explain more than 1000 words, waiting it's correct.
Old 7th April 2012, 03:02 PM   #1027
Russ White's Avatar
It is correct except that B5 should be B4.
Old 7th April 2012, 03:23 PM   #1028
Now it's OK?
Old 8th April 2012, 09:17 AM   #1029
gwikse is offline gwikse  Norway
Would it not also make sense to turn off input remapping (B7) when sidecar is switched to i2s?
Old 8th April 2012, 12:33 PM   #1030
Russ White's Avatar
No - for sidecar you would just leave it on.
You could switch it off for SPDIF, but it is not necessary.
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
