Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 6th April 2012, 11:47 AM   #1011
BrianDonegan's Avatar
Originally Posted by Turbon View Post
Now what's the best way to control this beast thru an MCU? Can everything be set from a MCU? No jumpers needed at all? No choises that has to be made before build it in?
Brgds
Simply leave the firmware chip (an MCU) off, and connect your MCU to the I2C header... Full control.
Twisted Pear Audio
Old 6th April 2012, 12:05 PM   #1012
Turbon is offline Turbon  Sweden
Turbon's Avatar
Hmmm, I feel an urge to have one of these...
Struggling.
Brgds
These are my principles, and if you don't like them... well, I have others.
Old 6th April 2012, 12:50 PM   #1013
Russ White's Avatar
Send a message via Yahoo to Russ White
Originally Posted by merlin el mago View Post
Thank you it's a very good information, connecting a wire between "B" on the Sidecar & pins 1 or 3 on the selector switch it's OK?
You can do it with whatever 2-bit selector position you like, but I would still disable SPDIF auto-detect in *all* cases where you are using PCM/DSD.
Less pulp more juice Twisted Pear Audio.
Old 6th April 2012, 03:31 PM   #1014
OK, Russ, for the two pole switch fix, just to be clear in my mind, like the attached image? And where should we ground B4?
Old 6th April 2012, 03:37 PM   #1015
merlin el mago's Avatar
Originally Posted by Russ White View Post
The best way to do this is with dual pole single throw switch. One pole should be connected to GND and "B5" on the Buf III I/O header - the other to 5V and "B" on the Sidecar. In this way when PCM/DSD is selected SPDIF auto-detection is disabled. You also get to use all 4 SPDIF selections.
Cheers!
Russ
Dual pole single throw switch, like this?
So one position connected to GND and "B5" on the Buf III I/O header - the other to 5V and "B" on the Sidecar so you switching between:
-GND on the Buf III I/O header and 5V on the Sidecar
-"B4" on the Buf III I/O header and "B" on the Sidecar
Where have I to connect the two middle pins of the switch?
Old 6th April 2012, 10:32 PM   #1016
sry but I´m a little confused:
according to leonbv B5 is IRR bandwidth (page 34 switch 6)
if one wants to change s/pdif autodetect switch 5 aka B4 is the one to throw to gnd
or did I miss something?
best
Leif
Old 6th April 2012, 11:13 PM   #1017
Russ White's Avatar
Originally Posted by SCompRacer View Post
OK, Russ, for the two pole switch fix, just to be clear in my mind, like the attached image? And where should we ground B5?
Yes the switch is correct.
You connect to B4 at EXT_IO. Refer to the integration guide.
Old 6th April 2012, 11:13 PM   #1018
Russ White's Avatar
-"B5" on the Buf III I/O header and "B" on the Sidecar
Look at the post above yours. The switch you show is not a DPST, but a DPDT.
Old 6th April 2012, 11:15 PM   #1019
Russ White's Avatar
best
Leif
B4 is SPDIF auto-detect Bypass (Switch 2:5) I will correct my post.
I forgot that the ports are 0 indexed and the switches 1 indexed.
I tried to edit posts to make this more clear.
Switch 2:5 is indeed EXT I/O port B4. Sorry for any confusion.
Old 6th April 2012, 11:43 PM   #1020
Good catch Leif. Thanks Russ! I attached a corrected image noting B4 in this post. I don't have the power to delete or change the image in my prior post but would encourage those who do to change it or delete it. Thanks!
Do I ground B4 to the chassis, VG on the Sidecar or a ground on the external I/O connector header?
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2013 diyAudio
