Buffalo III - flexibility without compromise. - Page 100 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 29th March 2012, 12:48 AM   #991
Hi Russ, I am thinking of adding an Isolation transformer for my Buffalo32S dac to clean up the power going to it - Is that a good idea ? - What's the minumum size you would recomend ??? --- Is there a maximum size ? Thank You, Sincerely, dean
Old 29th March 2012, 12:53 AM   #992
Russ White's Avatar
Send a message via Yahoo to Russ White
It really depends on your mains condition and the load.
My current home has very good wiring and little need for that. So I don't use one right now.
In the past I have used a 1000VA transformer to isolate my gear from the mains. But that size was based the size of the highest current draw I anticipated at that time. You would need to calculate the size that would work for you if need it.
Less pulp more juice Twisted Pear Audio.
Old 29th March 2012, 04:54 PM   #993
Hi Russ -Thank You! - I have very dirty mains here, --- I was wondering what I would need - Just for the BUFFALO 32S - ( Leaving plenty of headroom ) ....???
I want to initially going to use an Isolation Transformer just for it ----
I have your three transformers ... I have 2 LCBPS supplies, and the LCDPS Dual supply as well, - - - Thank You, dean
Old 30th March 2012, 03:38 AM   #994
Russ White's Avatar
Well a 250W unit should be adequate and a 500-1000W unit would be even better.
Old 30th March 2012, 06:43 AM   #995
Thank You for putting up with my newbie questions Russ, Kind Regards, dean
Old 30th March 2012, 08:32 AM   #996
You could go totally ott and use the same as me - 5Kva... bit big and heavy mind.
No I'm not joking either - it sits outside my office humming nicely to create silence inside from any traffos used after it.
Old 30th March 2012, 06:41 PM   #997
Hi Sonority, Thanks for the input....being new to diy - I could use all the suggestions I can get ;-)
Old 31st March 2012, 02:36 AM   #998
mjock3 is offline mjock3  United States
Just finished my Buffalo III Legato this afternoon. Not near broken in yet and this DAC sounds amazing. The soundstage is huge and images in precise locations. I have never put something together and had it sound this good right off the bat, I can't wait till it breaks in.
Thanks Russ, Brian, and LeonvB
Old 31st March 2012, 06:14 AM   #999
Can you show a schematic how to connect such stuff? The benefit will be no hum (not mechanical one) from traffos in afterwards circuits?
If for pristine and pure adoration - it's diyAudio dedication!
Old 31st March 2012, 01:59 PM   #1000
Russ White's Avatar
That would be better for a different thread. You actually might get more info on the power supplies forum.
Cheers!
Russ
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
