Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 16th October 2011, 06:06 PM   #751
AndriyOL is offline AndriyOL  Ukraine
Originally Posted by Russ White View Post
AndriyOL,
Good work so far!
I am sure we can sort you out, but lets move the conversation to the support forum so as not to spam the thread with help for your specific build.
Thanks!
Ok, no problem.
If for pristine and pure adoration - it's diyAudio dedication!
Old 18th October 2011, 09:50 PM   #752
4est is offline 4est  United States
Default Polarity of DIN on Sidecar
Brian/Russ,
There are no polarity marks on the Sidecar, and before I incorrectly solder eighty joints, I wanted to verify that this is an acceptable alternative to the supplied ribbon cable for the BIII/Sidecar/SPDIF 4.
Old 18th October 2011, 10:16 PM   #753
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - flexibility without compromise.
Yes, that should be fine.
Old 20th October 2011, 06:27 PM   #754
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Extracted from leon van Bommel B3 manual in your web site:
"The standard board requires an input voltage of 5.25V and it draws approximately 440mA when one is using the recommended set of Trident shunt regulators"
Are you sure the B3 draws 440mA with combo Tridents connected?
Old 20th October 2011, 06:34 PM   #755
barrows is offline barrows
Default merlin...
Why not measure yours? I have been following your problems on the Salas Bib thread, and it appears to me that you have some kind of problem, as over 700 mA in the reg should be plenty. I have found the Bib regs to work great with only 100 mA shunt current, and I doubt the B-II is drawing more than 500 mA.
If I were you I would measure the current draw on your B-III with your meter.
Old 20th October 2011, 06:42 PM   #756
The reg was going on perfectly for BII 5.5V I only changed the 5.25V for B3 & doesn't work?
I have sold my old B2 so can't measure.
Old 20th October 2011, 06:45 PM   #757
LeonvB is offline LeonvB  Netherlands
That's the measurement of Russ and at least 2 other users. Russ' initial estimate was 350mA, but that was a bit optimistic.
As a sidenote: one of my BII's with the Tridents, Mux and Toslink module pulls 450 mA from a Placid (CSS=+50mA), the other side with just Tridents uses slightly less.
Old 20th October 2011, 06:46 PM   #758
Default ???????
Measure the B-III, that is what you need to know. Just hook up some other supply, and measure the current draw, any 5 volt supply with adequate current will be fine, then you can use math to get the current draw at 5.25 volts, or any other voltage.
Old 20th October 2011, 07:06 PM   #759
NicMac is offline NicMac  Italy
NicMac's Avatar
Try first a dummy load (say 500 mA) on the supply to verify that the problem is not here.
Old 20th October 2011, 07:55 PM   #760
With a dummy load 11 ohms (two 22R in parallel) reg gets 5.25Vout so 0.5A
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 09:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 07:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 10:46 PM
Considering a compromise mashaffer Full Range 7 15th May 2006 12:45 AM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 03:19 PM
