Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th October 2011, 12:52 PM   #721
4est is offline 4est  United States
Default not that part
"Originally Posted by Russ White View Post
Something like this would work just fine:
15-44-5820 Molex Headers & Wire Housings
Then just a 2 x 10 2.54mm pitch standard male pin header for the other side."
This part is not the one that came with the kit, but something that can be used instead of the ribbon cable system.
Old 12th October 2011, 01:11 PM   #722
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Originally Posted by necplusultra View Post
can somebody confirm that this is the replacement part for the ribbon connector for sidecar
thanks.
http://www.molex.com/webdocs/datashe...R_TRP_CONN.pdf
You have PM
Old 12th October 2011, 01:13 PM   #723
AndriyOL is offline AndriyOL  Ukraine
I think this should fit also:
http://eu.mouser.com/ProductDetail/O...yoW1MVuri0I%3d
Does anybody know how to connect following PCM signal: MCLK, LRCK1, LRCK2, SCLK1, SCLK2, SDIN1, SDIN2, SDIN3, SDIN4 to appropriate BIII input?
If for pristine and pure adoration - it's diyAudio dedication!
Old 12th October 2011, 06:19 PM   #724
LeonvB is offline LeonvB  Netherlands
I think 3M connectors are used. Also I'll update the guide to include a full range of suitable Molex and possibly 3M connectors for those that need replacement numbers.
Old 12th October 2011, 06:22 PM   #725
I am actually going to be offering additional connectors in the Parts Bin. This will include various connectors used throughout our product line.
Old 12th October 2011, 06:30 PM   #726
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Brian you have PM about aerial female ribbon connectors
Old 12th October 2011, 06:47 PM   #727
Just updated the guide to 1.0.3: expanded the IDC part list, to include both 20 and 24 pin Molex and 3M partnumbers (for both Digikey and Mouser where possible), plus I added the board-to-board connectors mentioned earlier in this thread. For the rest just a few minor changes to clarify some things.
Old 13th October 2011, 04:29 PM   #728
Hi Leon,
Are you familiar with what I asked?
Old 13th October 2011, 04:56 PM   #729
Page 14 of the manual says it should be this:
MCLK = do not connect (master clock not connected on either BII or BIII)
SCLK1 or SCLK2 = BCK (SCLK = serial clock = bit clock)
LRCK1 or LRCK2 = D1 (LRCK = Word clock)
SDIN1, SDIN2, SDIN3, SDIN4 = D2 to D5
Old 13th October 2011, 05:46 PM   #730
Shall I tie together SCLK1 and SCLK2, LRCK1 and LRCK2 to connect to appropriate pins of BIII?
Source GND to BIII GND or it's not obligatory, as GND isn't I2S bus line and es9018 datasheet shows connections only for PCM serial data, fame clock (word clock), and bit clock?
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
