Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 1st June 2011, 10:35 AM   #61
leifchristensen is offline leifchristensen  Norway
but if you have solved offboard switch I2S and s/pdif itīs easy to split s/pdif into multiples....
imo
best
Leif
Norway
Old 1st June 2011, 12:00 PM   #62
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
It is not difficult do either. A little bread board and a couple relays is al it would take, and the breadboard is optional.
Less pulp more juice Twisted Pear Audio.
Old 1st June 2011, 12:01 PM   #63
Originally Posted by Russ White View Post
It is not difficult do either. A little bread board and a couple relays is al it would take.
in this case Iīll prefer to get it in with a teaspoon...
thxs in advance
best
Leif
Norway
Old 1st June 2011, 12:57 PM   #64
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
mmmmmm....... Are you sure? You would need to power the relays (psu, ŋtrafo?), or you could tap it from one of the output stage psus.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 1st June 2011, 12:59 PM   #65
once I get a schematic (even a simple one will do), Iīll build it
anyone?
thxs in advance
best
Leif
Norway
Old 1st June 2011, 01:01 PM   #66
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
OTTO 2:1 Switching Module
Old 1st June 2011, 01:07 PM   #67
MrMajestic is offline MrMajestic  Sweden
MrMajestic's Avatar
Originally Posted by BrianDonegan View Post
Would be great with something smaller and perhaps in stock as well
Old 1st June 2011, 01:09 PM   #68
thxs..thatīs a start
I have relays and the board isnīt really needed
best
Leif
Old 4th June 2011, 03:55 PM   #69
hobo king is offline hobo king  United States
No not by any means.
You could buy both and compare for yourself.
This implies II and III will be offered concurrently?
Do you have an estimate on price and release date?
Thx.
Hobo
Old 4th June 2011, 10:05 PM   #70
tailspn is offline tailspn
Hi Russ,
Could you comment on the DSD format that the BIII will accept? Will it accept Wordclock and SDIF2, and if so, how many channels. I would like to do two channels per BIII, but would be OK if it only could accept a single channel.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
Copyright ©1999-2017 diyAudio
