Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 13th January 2018, 08:03 AM   #1371
shattered_dream is offline shattered_dream  Germany
Thanks just saw that....
Another question, in the manual it's said that with change of firmware, the setting of the dip switches must be inverted... So if I still have the old firmware, do I have to invert the settings that are described in the manual?
Old 15th January 2018, 09:42 PM   #1372
Russ White is offline Russ White  United States
Russ White's Avatar
It depends on how old it is - if you don't get a good clean signal with it configured for I2S (test this at low volume) you will know you need to reverse the switches.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 17th January 2018, 08:13 AM   #1373
I'm just asking because I'm a little bit confused about the integration guide... At the setting of dip switches... If the manual says 'on' is it on or off with the old firmware?
Old 17th January 2018, 10:39 AM   #1374
OK solved thanks to Dimitris
Old 4th July 2018, 09:34 PM   #1375
orelli is offline orelli  Italy
Send a message via AIM to orelli Send a message via MSN to orelli Send a message via Yahoo to orelli
Where can I find the dip switch setting for beta firmware?
I've a Buffalo III stereo edition.
Thanks.
Old 5th July 2018, 12:44 AM   #1376
Russ White's Avatar
Hmm - not sure what beta firmware you mean.
Audio
Old 5th July 2018, 08:36 PM   #1377
I purchased BIII in the first months of 2017 , the board was fit with a IC firmware, but in the package there was another IC named "beta firmware".
Old 12th July 2018, 04:37 PM   #1378
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Buffalo III - flexibility without compromise.
The "beta" firmware (then) is the current production firmware.
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
