Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 22nd August 2016, 07:17 AM   #1361
bitinhvi is offline bitinhvi  Viet Nam
Send a message via Yahoo to bitinhvi
Originally Posted by Russ White View Post
You must wire it in B3SE mode. Joining D1 to D5 and joining D2 to D4,D6. You could do this with the jumpers or with plain wire at the inputs - your choice. Then you must set the DIP switch to operate in stereo mode (switch 2 position 8).
Thank you, Russ.
I prefer to join them by jumpers. And SE mode.
So am I correct if understand that I should USE all jumpers?
JPCM1 (JPCM1, 3)
JPCM2 (JPCM2, 1)
JPCM3 (JPCM3, 2)
JDSD1 (JDSD1, 5)
JDSD2 (JDSD2, 4)
Then active Input remapping by SW2 position 8.
Old 20th September 2016, 07:29 PM   #1362
Kim Bay Smidt is offline Kim Bay Smidt  Denmark
Kim Bay Smidt's Avatar
I just posted a nice case with display and microcontroller over in the Swap Meet forum for the Buffalo III DAC. There are optional modules too.
Old 27th December 2016, 04:11 AM   #1363
Hi Russ, Brian
Finally I could achieve my target to run both DSD and PCM by connecting just JPCM1,2 and JDSD1,2.
DSD and PCM file sound smoothly without pop,click but very low volume. Normally, my amplifier is in 12h position, now I have to turn it to max position, but it is still far from normal sound level.
I am using IVYIII and notice that Buffalo III volume port doesn't work, same level at any operation.
Anything wrong or just normal because jumper changing so I have to increase gain in IVYIII?
Old 14th October 2017, 05:05 PM   #1364
Russ White is offline Russ White  United States
Russ White's Avatar
Many of you will be interested in this:
Introducing the Buffalo III-SE-Pro 9028/9038
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 14th October 2017, 05:34 PM   #1365
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
Buffalo III - flexibility without compromise.
Cheers!
Russ
Oh yes! Already ordered.
uFLs are pre mounted , Yes???
I mangled them the last time.
Currently listening to F4 or F6/w curve matched SemiSouth outputs
Old 14th October 2017, 05:45 PM   #1366
Russ White's Avatar
Yes pre-mounted! So if you use terminal block please mount the terminal block on the bottom!
Audio
Old 5th December 2017, 09:03 PM   #1367
Sidiropa is offline Sidiropa  Switzerland
Hi Russ, as the github links to the latest non-pro BIII firmware do not work anymore, can you please make it available either on the existing github or the documents section in the TPA site?
Thank you very much.
Old 5th December 2017, 09:15 PM   #1368
Russ White's Avatar
Hmm - I think I might have just made it private for now - I will move it over and make it public
It also needs a rewrite...
Audio
Old 9th January 2018, 01:35 PM   #1369
shattered_dream is offline shattered_dream  Germany
Stupid Question...
Bought a Buffalo III from a guy here at the forum... Seems to be an older one with an old firmware from 2012..... How can I update this firmware?
Old 12th January 2018, 03:01 PM   #1370
Russ White's Avatar
Originally Posted by shattered_dream View Post
Stupid Question...
You can order new firmware from the site if you like. But you may not need to.
Audio
Buffalo III - flexibility without compromise.Hide this!Advertise here!
Legato or IVY III outputs for Buffalo II? natzev_i Twisted Pear 272 21st March 2011 08:08 PM
Buffalo Dac original vs Buffalo II mrtakib Digital Line Level 7 24th August 2010 06:47 AM
How much compromise, small EQ'ed sub audiobomber Subwoofers 10 15th March 2007 09:46 PM
Considering a compromise mashaffer Full Range 7 14th May 2006 11:45 PM
OB subs: Best compromise? MtnBob Subwoofers 13 26th May 2004 02:19 PM
